× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
R7000
Sparky723
Follower
R7000
I have 100 mbps at my house. I have plugged the ethernet cord directly into my laptop and done speed tests through fast.com
I either get 100 or 110 mbps.
However, when I pmug the ethernet cord back into the router and check fast.com on the laptop, the best I can get is 35 mbps.
Can the router be faulty?
We have a very secure password.
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 2
Kitsap
Master
Re: R7000
Additional information is needed.  Please confirm the model number of your router.  The A7000 in the footer of your message is a USB adapter.
What is the manufacturer and model number of your modem/gateway?  Could it be a combination device that is also a router?  Cascading two routers can cause problems.
When you connect the router to your modem with an ethernet cable and then check the speed on your laptop, how is the laptop connected to the router?  Via Wi-Fi or an ethernet cable?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 484 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
