× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Using A7000 with raspberry pi 4.
gibby101
Follower
Hi
I have a spare A7000 and would like to use it with my media streamer which is a raspberry pi 4 running Kodi. I plugged it and it sees the USB device but it doesnt seem to recognize it as a wifi adapter.
Thanks!
Steve
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 2
schumaku
Guru
Re: Using A7000 with raspberry pi 4.
Some information to start with is shown here https://wikidevi.com/wiki/Netgear_A7000 - as this site will disappear soon:
The Edimax driver EW-7833UAC_Linux_Driver_4.3.21 linked to on the right works with Ubuntu 16.04 Kernel 4.4.0-116 if you add the Netgear device ID.
Add the line {USB_DEVICE(0x0846, 0x9054),.driver_info = RTL8814A}, /* Netgear - A7000 */ to the CONFIG_RTL8814A section in <driver source folder>/os_dep/linux/usb_intf.c.
It's line 213 in the version mentioned above.
Then make, and sudo make install as described in the readme.
You need an ARM driver for your Pi btw.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2190 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
