McGoo01's avatar
McGoo01
WNDA3100v2 Region Change
Ever since I bought this N600 WiFi Dual Band USB Adapter I had trouple with the connection
to my home network. One day it works fine, another day it doesn´t work at all. I have the newest
version of the Netgear genie 2.2.0.5. Today I found another clue why it may not work.
I moved over here from Germany and have a german version of Windows on my PC.
The Adapter I bought here in the USA where I´m living now. In the software under
Other-Region it says Europe. Does anybody know if this could be the cause of my
Problems and how to change the Region to USA?? I´m downloading the software
by selecting US, the Adapter is bought in the US, but for some reason it only recognices
Region: Europe. I´m guessing it´s because of my german Windows. Any solution I
would highly appreciate.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi McGoo01,
    Welcome to Community!
    Were you able to download the driver for US? Or can you only see driver for Europe region? Please provide the link of the download page.
    JamesGL
    Community Team
    • McGoo01's avatar
      McGoo01
      Hallo JamesGL,
      here is the link for the download:
      http://downloadcenter.netgear.com/#register
      I found a solution for my problem. I bought a TP-Link WiFi Range Extender TL-WA850RE, and with this one
      the connection works fine. So, my logical explanation would be: The cause of the problem is the Arris-TG862-Router
      from Brighthouse. But every other wireless device works great with the router, even from the same location. So,
      I don´t know. At least I have a functioning system now.
                  McGoo01
      • JamesGL's avatar
        JamesGL
        Hi McGoo01,
        Would it be possible to install it on a different computer  and check if it has the same problem.
        JamesGL
        Community Team
