× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
connection issue
thx4service
connection issue
Hi
Suddenly Wps doesn't light up
I kept pressing the button, but it didn't work.
I dont know what to do..
Model: A6210|AC1200 High Gain WiFi USB Adapter
Message 1 of 10
Guru
Re: connection issue
You have the A6210 adapter?
You can always installing/connect manually instead of using wps.
The guide goes over it.
https://www.netgear.com/support/product/A6210.aspx
Message 2 of 10
thx4service
I've been using it for about a year and it suddenly doesn't work.
Message 3 of 10
Guru
Ok, so if the wps button doesn't work, try the manual method.
Message 4 of 10
thx4service
Manual method? How can i do ??
Message 5 of 10
Guru
The support page I linked to prior?
It has the manual/guides that go over that.
Message 6 of 10
thx4service
Oh thx Ill try it
Message 7 of 10
thx4service
oh god finally im connect wifi
but pop up the new problem...
my conncection state is very unstable
i looked at this link and try
https://kb.netgear.com/23352/A6200-A6210-WNDA3100v2-wireless-adapter-intermittently-disconnects
but It hasn't been solved
Message 8 of 10
Guru
Saying your connection is unstable doesn't say much.
What is your link speed?
what is your actual tested speed?
how far from the router is the adapter?
Whats between the adapter and the router (what materials)?
Whats actually happening. Saying its unstable can mean many different things
Message 9 of 10
thx4service
oh i mean frequently disconnected
Whats between the adapter and the router (what materials)? ARE ALL FINE... 😞
I used it for a year without a problem
Is it possible that the device is old?
Thank you always for your reply.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1658 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
