ergo-ogre's avatar
ergo-ogre
Follower
Feb 16, 2022
GS305P power supply
Good morning!
I work for a university in the southern US and a faculty member that I work with recently returned to me a known working GS305P switch without the power supply.  Of course, they have no idea where it is.  Can someone direct me to a place where I can buy a replacement power supply for this unit?  I would really hate to have to throw it away.
The power input specs are 48V/1.25A
Thank you!
  • plemans's avatar
    You can find matching power supplies from 3rd party sellers like amazon that work fine. So long as they match that 48v and at least 1.25a supply. I've used replacements several times from there.
  • Does the included Power supply for the GS305EP accept BOTH 120v AC & 240v AC power at the source (wall outlet)?
    (Our application requires 240v AC power compatibility).
    Thanks in advance !
    • schumaku's avatar
      schumaku
      Difficult to answer, since Netgear does supply power supplies and adapters fitting not only the market and region specific AC plug, but also the primary AC voltage. The formal answer is on the supplied adapter label resp. the data printed to it.
      Some community members report since these are switching power supply there -might- be workable beyond of the formal primary AC voltage designation, while others like ne always leave a warning doing so.
ProSupport for Business
