Orbi WiFi 7 RBE973
Reply
Gigabit unmanaged switch not distributing signal to other ports
gfranke
Trying to install a GS105v5 switch to extend my network.
Powered up and have the internet input in Port1.  Plugged two cables into Port2 and Port3 and they do not light up.  No signal is being distributed.
Help
Thanks
Gary
Message 1 of 6
Accepted Solutions
gfranke
Re: Gigabit unmanaged switch not distributing signal to other ports
Thanks to those who replied.
Turns out I needed a POE switch.  Both output cables from the switch have to first provide power and data to VoIP phones.  A non-POE switch won't work.
Thanks for the help.  I learned something.
Gary
Message 5 of 6
All Replies
Guru
If you move the connection from port 1 to port 2, does port 2 light up?
Whats hooked up to the other 2 cables?
Message 2 of 6
gfranke
When I move the incoming cable from port 1 to port 2, port 2 lights up.
The other two cables are going to two different cubicles.
I returned the first unit thinking it might be defective and bought another.  Same problem.
Thanks
Message 3 of 6
Guru
for 2 devices to have the exact same issue makes me suspect the cables or devices plugged in. but it gets more complicated becaues it works fine in port 2.
Does port 1 work with other devices plugged into it?
Message 4 of 6
gfranke
Gary
Message 5 of 6
Guru
I didn't realize you were trying to power something with it. My bad!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1500 views
  • 0 kudos
  • 2 in conversation
Announcements
