ThiagoEmanuel
Aug 25, 2021Follower
HUB EN104
Hello,
Im Thiago, Test Engineer from Jabil Brazil and we are needinga quote for router below:
https://www.netgear.com/support/product/EN104.aspx#docs
I need of a router with BCN connector and it needs as well of EthernetHub10baset (on attach).
It's router is dedicated for an equipment inside the factory here.
Thanks
1 Reply
Very difficult to find "new" 10BASE2 equiped switch or hub (it does not really matter) as we face technology from the early 1980ties here.
I'd look around on eBay and the like ...
Alternate approach could be a 10BASE2 to 10BASET Media Converter, and add some 10M capable switch. Converters might be easier to find with industry suppliers.
