Orbi WiFi 7 RBE973
Reply
How to set port mirroring for GS110TPv3
MayBeYas
Hi all,
I cannot find Port Mirroring setting page on https://192.168.0.239
Monitoring tab shows only "Logs".
I tried log on as "NETGEAR Insight Mobile App and Insight Cloud Portal" but I couldn't find too.
How can i show Port Mirroring setting page?
Best Regards,
Yas
Message 1 of 7
schumaku
Guru
Re: How to set port mirroring for GS110TPv3
Hi Yas,
What is the GS110TPv3 firmware version in place?
Not sure this moment if (by mistake?) the port mirroring might be disabled if the device is Insight managed.
-Kurt
Message 2 of 7
MayBeYas
Hi kart
Thank you for reply.
Firmware version is 7.0.1.20
"might be disabled if the device is Insight managed."
I thinmk so too. Insight seems to obstacle Port Mirroring because I used it two years ago.
Should I buy subscription to use Port Mirrorring? or Should I update the firmware?
Best Regards,
Yas
Message 3 of 7
schumaku
Guru
Yas,
On the Insight managed swiches I have at hand, Port Mirroring is available from Insight (certainly from theWeb UI), but not from the local Web UI while in Insight mode.
Start with putting up a current firmware to the switch from https://www.netgear.com/support/product/gs110TPv3.aspx -> Downloads
While I love Insight, just for a single switch it does not always make real sense.
-Kurt
Message 4 of 7
MayBeYas
Hi Kurt,
Okay I will try updating firmware and using Insight.
Thanks.
Best Regards,
Yas
Message 5 of 7
schumaku
Guru
Port Mirroring must bei available in pure local Web management while not linked to Insight, too
Message 6 of 7
MayBeYas
To all supporters
Thank you for your comment . and I’m sorry for late reply.
Finally I can use port mirroring function by Insight setting .
It was very complicated to setup insight registeration.
Anyway thanks to all supporters.
Best Regards,
Yas
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1293 views
  • 2 kudos
  • 2 in conversation
Announcements
