n4hmr
Feb 14, 2024Aspirant
Need GS316 gigabit switch Power supplies
We have 6 GS316 Gigabit switches that some jackass lost the power supplies for these units. The original P/S info is Mdl# AD2025F10. P/N 332-10740-01 and Type 007-1LF.
I have found some P/S that are Mdl# AD2071F10. P/N 332-10922-01 and Type 007-1LF.
Both are 12VDC 1A supplies with the correct plug polarity. Could this alternate supply be used with the GS316?
Please help. Thanks
1 Reply
As long as voltage/polarity are the exact same and its at least the same (can be more) amps, it should work. I've done it with other routers/switches fine.
