- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Attached USB Device as iSCSI volume
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it possible to attach a USB device to a ReadyNAS Pro or ReadyNAS RN102 and create an iSCSI volume from that?
I would like to attach an external USB 3.0 drive that is encrypted with bitlocker to the ReadyNAS, and then be able to decrypt it from a client PC. I was thinking that maybe if it was treated as iSCSI this might be possible.
The goal of this would be to unlock a bitlocker encrypted drive that is attached to the NAS via USB for backups.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
What you could do is create a VHD file encrypted with bit locker, and host that on the NAS - either on an internal volume or on the USB drive. If the USB drive was formatted as NTFS, that would have a similar effect (you could access the VHD directly from a Windows PC by attaching the USB drive to the PC, or via the NAS).
Decryption of the VHD is done in the PC client (to the NAS it is just a big file).
http://www.howtogeek.com/193013/how-to-create-an-encrypted-container-file-with-bitlocker-on-windows/ shows how to make the encrypted vhd
https://www.youtube.com/watch?v=IBhej67wD98 shows how to mount it from a network share.
One caveat - VHD support requires Windows professional, enterprise, or ultimate.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Attached USB Device as iSCSI volume
No. iSCSI LUNs are created on the internal volume.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Stephen, if I have created a VHD file encrypted with bitlocker that is hosted on the NAS through USB, how can i back up to that VHD?
For instance, if I attach the VHD from a windows client, it appears as local drive F:
If I wanted to Rsync to that USB Drive, what would the file path be?
It's a little confusing.
If you could assist I would be grateful.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
VHD (virtual disk) is similar to iSCSI. You mount the VHD from the PC (as I guess you have done). Then you access it just like a regular drive from the PC.
But like iSCSI that's pretty much all you can do. The VHD file is opaque to the NAS. And of course since it is client-side encrypted, only clients with the key can decrypt it.
If that is not the behavior you wanted/expected, perhaps you should tell us more about what you want to do with the disk..
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did state what I wanted to do with the disk.
"The goal of this would be to unlock a bitlocker encrypted drive that is attached to the NAS via USB for backups."
I just want to backup to an encrypted USB drive, preferably using RSYNC or some other "intelligent" backup protocol, without having to have a PC running all the time, but it looks like I might have to use a different method. The encryption doesn't have to be bitlocker, but I don't know of any other external disk encryption that's even close to compatible with the NAS.
There is a program called Dislocker that allows linux based systems to mount bitlocker encrypted drives that can be found here http://www.hsc.fr/ressources/outils/dislocker/
I would take a swing at installing it; however, there isn't very much information about which flavor of linux that NAS runs, and that leaves me in a position where I'm not even sure if it is possible to install that program because of this.
Thanks for the help Stephen. I do appreciate it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was interpreting that as backing up from a PC, not from Frontview. So the use case would be to ensure that sensitve info can't be read if someone hacks the NAS. I was assuming that since you are specifically thinking about bitlocker, which is Windows only.
Extending the drive encryption used by the NAS to the USB drives is a different use case, and VHD won't help you there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You make a good point. I should have been clearer on what I was trying to achieve; I understand the confusion now. I've been posting about this, asking in different ways for some time on how I can plug an encrypted USB drive into the NAS, and backup the NAS to that USB drive, but I've yet to find a good solution.
I tried plugging the encrypted USB drive into a Windows PC, and using Deltacopy to enable RSYNC cabilities on that Windows PC, but I've had some problems with it, and I don't think it will be the solution I need. My ideal situation is to use the USB connection directly on the NAS, and backup the NAS to an encrypted USB drive without having to use a separate machine.
If VHD won't help me there: Do you know of anything that would help me there?
Would you classify the ReadyNAS Linux as "Fedora-like" or "Debian-like"? Neither?
Dislocker install instructions use these terms.
Thanks again Stephen.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not thinking of anything. iSCSI won't work. You can encrypt an iSCSI LUN from the client, but that presents the same issues as VHD. And the LUN is opaque to the NAS even if it isn't encrypted.
VHD can work if you are running deltacopy (or other backup software) on the PC (from the PC point of view you are rsyncing from one drive to another). But not if you want to run rsync on the NAS.
The RN102 runs debian etch.
