xeltros's avatar
xeltros
Apprentice
Jan 22, 2014
Cisco firewall before RN104.
Hi guys,
I know this forum is for readyNAS but I struggle configuring CISCO NAT to provide external access to my ReadyNAS. I was wondering if someone could be of some help here. I bought a cheap second-hand CISCO 1711 with IOS 12.4T15 adv security. I wanted to have a real firewall protecting a device with no firewall and since I needed to practice on CISCO devices...
FYI I used to have CCNA (academic) 1 to 4 but didn't practice for a while and never on 1711 or alike.
The goal is to set up things like this :
INTERNET router (192.168.0.1) => CISCO FA0 (192.168.0.10) => CISCO ACL with OSI layer7 firewall + NAT => CISCO FA2 (172.16.0.254) => RN104 ETH1 (172.16.0.200)
In a second time I would like to add an L2TP/Ipsec VPN on 10.0.0.0/24 subnet for remote access but I'll do that later.
I configured my interfaces, everything works fine, for the fa2 I had to setup VLAN172 to be able to handle layer3 capabilities for switched ports. I can ping and access the web interface of the NAS (the ETH1 with 172.16.0.200) from my computer (192.168.0.0/24) but nat is not working when I try to access 192.168.0.10:60443 which should be redirected to 172.16.0.200:443 I got nothing.
@boot I got :
show ip nat translation
Pro Inside global Inside local Outside local Outside global
tcp 192.168.0.10:60443 172.16.0.200:443 --- ---
When trying to access I get :
tcp 192.168.0.10:60443 172.16.0.200:443 192.168.0.35:53327 192.168.0.35:53327
Seems to me that's working as expected but I get no access to the NAS.
Can anyone be of any help ? I can send the full config if needed.
  • Whats your Nat configuration?
    I presume u have the FW config disabled to get the NAT part working first?
    Just FYI the FW is not a L7 Firewall in the sense that term is commonly used. It does support pin-holing which requires some limited inspection of some protocols, but its not a L7 Firewall. For what you are using it for though the L3/L4 capabilities are fine.
    A.
  • You assume right. NAT Only (and VLans to be able to manage switched interface up to layer 3).
    Layer 7 means applicative filtering. I think Cisco can differentiate SSH from HTTP no matter the TCP port used, so it's more than layer4. That said it is limited to some protocols and is no way near what checkpoint can do but I think it will be better than IPTables anyway. What you mean by it's not layer7 is that it only reads headers and do not test the entire instructions of the packet ?
    You seem to know your stuff so, I think you should be able to read the conf directly (with a few modifications on username/passwords of course ;) ).
    Building configuration...
    Current configuration : 1568 bytes
    version 12.4
    service timestamps debug datetime msec
    service timestamps log datetime msec
    service password-encryption
    hostname kerberos
    boot-start-marker
    boot-end-marker
    enable secret 5 EnableSecret
    aaa new-model
    aaa session-id common
    ip cef
    no ip domain lookup
    ip domain name kerberos.mydomain.com
    multilink bundle-name authenticated
    username SSHUser secret 5 SSH-User-Password
    archive
    log config
    hidekeys
    ip ssh version 2
    interface BRI0
    no ip address
    encapsulation hdlc
    shutdown
    interface FastEthernet0
    ip address 192.168.0.10 255.255.255.0
    ip nat outside
    ip virtual-reassembly
    duplex auto
    speed auto
    interface FastEthernet1
    description VM
    switchport access vlan 10
    interface FastEthernet2
    switchport access vlan 172
    interface FastEthernet3
    interface FastEthernet4
    interface Vlan1
    no ip address
    interface Vlan10
    ip address 10.0.0.254 255.255.255.0
    interface Vlan172
    ip address 172.16.0.254 255.255.255.0
    ip nat inside
    ip forward-protocol nd
    ip route 0.0.0.0 0.0.0.0 FastEthernet0
    ip route 0.0.0.0 0.0.0.0 192.168.0.1
    no ip http server
    no ip http secure-server
    ip nat translation timeout 30
    ip nat translation tcp-timeout 30
    ip nat translation udp-timeout 30
    ip nat translation icmp-timeout 30
    ip nat inside source list 1 interface FastEthernet0 overload
    ip nat inside source static tcp 172.16.0.200 443 192.168.0.10 60443 extendable
    control-plane
    line con 0
    line aux 0
    line vty 0 4
    transport input ssh
    end
    As you can see no ACL and when going directly to 172.16.0.0/24 network I can access the NAS via HTTPS so no connectivity problem. Just the NAT/PAT not working I think. This is probably something I totally forgot but as said I'm a bit rusty with Cisco.
  • Thought you would do needed an outside nat rule since 192.168... Is an outside interface.
    Also try
    #debug ip nat detailed
    A.
  • "Layer 7 means applicative filtering. I think Cisco can differentiate SSH from HTTP no matter the TCP port used, so it's more than layer4. That said it is limited to some protocols and is no way near what checkpoint can do but I think it will be better than IPTables anyway. What you mean by it's not layer7 is that it only reads headers and do not test the entire instructions of the packet ? "
    Ah you must be referring to the T train NBAR based FW. That application recognition technology is pretty basic and limited, also I wouldn't advocate using anything but "well known port" policies when using a FW to essentially reduce the attack surface as you seem to be doing.
    Application based FW features are really for "acceptable use " type of purposes, I.e. Don't allow BitTorrent traffic out of my network, stop people from using Dropbox etc.
    A.
  • For the firewall, yes my usage is pretty basic I am to use HTTP(S)/(s)FTP/SSH mainly, maybe a little bit of DNS. I will also need the VPN (L2TP/IPSec on the router) to pass through. Anything more evolved than that will be filtered via VPN credentials only (once connected you get full access). I'd just like to filter a little bit and practice Cisco doing it. I'm giving up the IPS feature because having a second hand router I don't have the account it was registered with and the router's memory/CPU is limited but would have been nice.
    I'm testing out the NAS command from this conf (the same you already read except I added description to interfaces and with no NAT except inside/outside int definitions)
    Current configuration : 1526 bytes
    version 12.4
    hostname kerberos
    boot-start-marker
    boot-end-marker
    enable secret 5 SECRET
    aaa new-model
    ip cef
    no ip domain lookup
    ip domain name kerberos.mydomain.fr
    username xeltros secret 5 SECRET
    archive
    log config
    hidekeys
    ip ssh version 2
    interface BRI0
    no ip address
    encapsulation hdlc
    shutdown
    description INTERNET (bad guys)
    ip nat outside
    duplex auto
    speed auto
    description VLAN10 (VPN) dedicaced interface
    description VLAN172 (DMZ) dedicaced interface
    interface Vlan1
    no ip address
    interface Vlan10
    description future VPN (good distant guys)
    ip nat inside
    interface Vlan172
    description DMZ (good protected guys)
    ip nat inside
    no ip http server
    control-plane
    line con 0
    line aux 0
    line vty 0 4
    transport input ssh
    end
    I'll send raw results to avoid any error from my side.
    IP NAT detailed debugging is on (activated after sending the conf)
    I do a full router reload between each configuration to be sure to start on the clean conf above.
    With no NAT (witness config)
    I will only be testing NAT on the other configs, since basic IP shouldn't be disturb much by NAT only.
    FROM ROUTER :
    ping 192.168.0.1 (internet gateway) => OK
    ping 172.16.0.200 (NAS eth1) => OK
    FROM MAC (having a static route to 172.16.0.200(NAS eth1) via 192.168.0.10 (Router FA0)
    => ping 172.16.0.200 => OK
    => ping 192.168.0.10 => OK
    => ping 172.16.0.254 => OK (router vlan 172)
    => web interface 172.16.0.200 => OK
    => web interface 192.168.0.10 => TIMEOUT
    NAT INSIDE (the one I already posted)
    Web interface (192.168.0.10) => TIMEOUT
    router output :
    kerberos#sh ip nat tra
    kerberos#
    *Jan 21 08:29:37.591: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [47325]
    *Jan 21 08:29:37.595: NAT*: TCP s=54949, d=60443->443
    *Jan 21 08:29:37.595: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [47325]
    *Jan 21 08:29:37.735: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [56852]
    *Jan 21 08:29:37.735: NAT*: TCP s=54949, d=60443->443
    *Jan 21 08:29:37.735: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [56852]
    *Jan 21 08:29:37.935: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [46679]
    *Jan 21 08:29:37.939: NAT*: TCP s=54949, d=60443->443
    *Jan 21 08:29:37.939: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [46679]
    *Jan 21 08:29:38.139: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [59982]
    *Jan 21 08:29:38.139: NAT*: TCP s=54949, d=60443->443
    *Jan 21 08:29:38.139: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [59982]
    *Jan 21 08:29:38.339: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [27074]
    *Jan 21 08:29:38.339: NAT*: TCP s=54949, d=60443->443
    *Jan 21 08:29:38.339: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [27074]
    *Jan 21 08:29:38.543: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [14430]
    *Jan 21 08:29:38.543: NAT*: TCP s=54949, d=60443->443
    *Jan 21 08:29:38.543: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [14430]
    *Jan 21 08:29:38.843: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [748]
    *Jan 21 08:29:38.843: NAT*: TCP s=54949, d=60443->443
    *Jan 21 08:29:38.843: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [748]
    *Jan 21 08:29:39.343: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [38102]
    *Jan 21 08:29:39.343: NAT*: TCP s=54949, d=60443->443
    *Jan 21 08:29:39.343: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [38102]
    *Jan 21 08:29:40.247: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [40722]
    *Jan 21 08:29:40.247: NAT*: TCP s=54949, d=60443->443
    *Jan 21 08:29:40.247: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [40722]
    *Jan 21 08:29:42.055: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [59666]
    *Jan 21 08:29:42.055: NAT*: TCP s=54949, d=60443->443
    *Jan 21 08:29:42.055: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [59666]
    *Jan 21 08:29:45.711: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [18061]
    *Jan 21 08:29:45.715: NAT*: TCP s=54949, d=60443->443
    *Jan 21 08:29:45.715: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [18061]
    *Jan 21 08:29:52.391: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [15853]
    *Jan 21 08:29:52.391: NAT*: TCP s=54949, d=60443->443
    *Jan 21 08:29:52.391: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [15853]
    *Jan 21 08:29:59.191: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [26239]
    *Jan 21 08:29:59.191: NAT*: TCP s=54949, d=60443->443
    *Jan 21 08:29:59.191: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [26239]
    tcp 192.168.0.10:60443 172.16.0.200:443 192.168.0.26:54949 192.168.0.26:54949
    kerberos#
    *Jan 21 08:30:59.211: NAT: expiring 192.168.0.10 (172.16.0.200) tcp 60443 (443)
    NAT OUTSIDE
    using command ip nat outside source static tcp 192.168.0.10 60443 172.16.0.200 443 extendable
    router output :
    *Jan 21 08:40:00.251: ipnat_add_static_cfg: id 2, flag 6
    *Jan 21 08:40:00.251: id 2, flags 0, domain 1, lookup 1, from_addr C0A8000A, from_mask FFFFFFFF, from_port EC1B, to_addr AC1000C8, to_port 1BB to_mask FFFFFFFF, proto 6
    *Jan 21 08:40:00.255: NAT: installing alias for address 172.16.0.200
    kerberos(config)#do sh ip nat tra
    tcp --- --- 172.16.0.200:443 192.168.0.10:60443
    NAT OUTSIDE BIS
    using command ip nat outside source static tcp 172.16.0.200 443 192.168.0.10 60443 extendable
    router output :
    *Jan 21 08:52:43.003: ipnat_add_static_cfg: id 2, flag 6
    *Jan 21 08:52:43.003: id 2, flags 0, domain 1, lookup 1, from_addr AC1000C8, from_mask FFFFFFFF, from_port 1BB, to_addr C0A8000A, to_port EC1B to_mask FFFFFFFF, proto 6
    *Jan 21 08:52:43.007: NAT: installing alias for address 192.168.0.10
    tcp --- --- 192.168.0.10:60443 172.16.0.200:443
    NAT INSIDE BOTH WAYS
    ip nat inside source static tcp 192.168.0.10 60443 172.16.0.200 443 extendable
    router output :
    tcp 172.16.0.200:443 192.168.0.10:60443 --- ---
    kerberos(config)#
    *Jan 21 08:46:59.723: NAT*: o: tcp (192.168.0.26, 55025) -> (192.168.0.10, 60443) [56183]
    *Jan 21 08:46:59.727: NAT*: TCP s=55025, d=60443->443
    *Jan 21 08:46:59.727: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [56183]
    *Jan 21 08:46:59.727: NAT: i: tcp (172.16.0.200, 443) -> (192.168.0.26, 55025) [44274]
    *Jan 21 08:46:59.731: NAT: TCP s=443->60443, d=55025
    *Jan 21 08:46:59.731: NAT: s=172.16.0.200->192.168.0.10, d=192.168.0.26 [44274]
    tcp 192.168.0.10:60443 172.16.0.200:443 192.168.0.26:55025 192.168.0.26:55025
    NAT address to address
    command ip nat inside source static 172.16.0.200 192.168.0.10
    *Jan 21 08:56:03.379: ipnat_add_static_cfg: id 3, flag 6
    *Jan 21 08:56:03.379: id 3, flags 0, domain 0, lookup 0, from_addr AC1000C8, from_mask FFFFFFFF, from_port 0, to_addr C0A8000A, to_port 0 to_mask FFFFFFFF, proto 0
    *Jan 21 08:56:03.383: NAT: installing alias for address 192.168.0.
    --- 192.168.0.10 172.16.0.200 --- ---
    (while pinging 192.168.0.10 from MAC (ping OK))
    kerberos(config)#
    *Jan 21 08:56:25.847: NAT*: o: icmp (192.168.0.26, 56136) -> (192.168.0.10, 56136) [4938]
    *Jan 21 08:56:25.847: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [4938]
    *Jan 21 08:56:26.847: NAT*: o: icmp (192.168.0.26, 56136) -> (192.168.0.10, 56136) [39977]
    *Jan 21 08:56:26.847: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [39977]
    NAT address to address with 192.168.0.11
    command : ip nat inside source static 172.16.0.200 192.168.0.11
    *Jan 21 08:58:54.867: ipnat_add_static_cfg: id 5, flag 6
    *Jan 21 08:58:54.867: id 5, flags 0, domain 0, lookup 0, from_addr AC1000C8, from_mask FFFFFFFF, from_port 0, to_addr C0A8000B, to_port 0 to_mask FFFFFFFF, proto 0
    *Jan 21 08:58:54.867: NAT: installing alias for address 192.168.0.11do sh ip nat tra
    --- 192.168.0.11 172.16.0.200 --- ---
    (while pinging 192.168.0.11 from MAC, ping OK)
    kerberos(config)#
    *Jan 21 08:59:31.347: NAT*: o: icmp (192.168.0.26, 24137) -> (192.168.0.11, 24137) [29439]
    *Jan 21 08:59:31.351: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [29439]
    While accessing web interface (192.168.0.11, TIMEOUT)
    *Jan 21 09:03:59.871: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [18909]
    *Jan 21 09:03:59.871: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [18909]
    *Jan 21 09:04:00.871: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [22728]
    *Jan 21 09:04:00.871: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [22728]
    *Jan 21 09:04:01.875: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [5438]
    *Jan 21 09:04:01.879: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [5438]
    *Jan 21 09:04:02.883: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [64158]
    *Jan 21 09:04:02.883: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [64158]
    *Jan 21 09:04:03.887: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [16652]
    *Jan 21 09:04:03.887: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [16652]
    *Jan 21 09:04:04.891: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [47748]
    *Jan 21 09:04:04.895: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [47748]
    *Jan 21 09:04:06.907: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [42904]
    *Jan 21 09:04:06.907: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [42904]
    *Jan 21 09:04:10.927: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [50389]
    *Jan 21 09:04:10.927: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [50389]
    *Jan 21 09:04:18.935: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [33094]
    *Jan 21 09:04:18.935: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [33094]
    *Jan 21 09:04:34.967: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [50797]
    *Jan 21 09:04:34.971: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [50797]
    *Jan 21 09:05:07.075: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [61870]
    *Jan 21 09:05:07.075: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [61870]
    None of the config got me to access the web interface, but as far as I can judge with ip nat inside anything goes well on the router... (PS when there is no debug in NAT, that means NAT wasn't triggered, I copied the output I got).
    Because everything seems fine to me, I wondered if I should set a route, but the router is directly connected it knows where to send anything. Moreover when accessing 172.16.0.200 telling my MAC to route via 192.168.0.10 it works so I don't see any reason this wouldn't work while doing NAT...
    Xel
ProSupport for Business
