juaky
Mar 21, 2017Aspirant
FS Check stuck at 46%
Hello
I got a bunch of alerts the other night and dont know what to do at this point. do i leave it checking the files?
I have XRaid 4GB. Alll drives were upgraded a few years ago.
here is a run down of what happened:
[Sat Mar 18 05:06:03 EDT 2017] Access to the disk on channel (??) is producing I/O errors. Although the array is still redundant, please replace this drive as soon as possible, as it is likely to fail soon.
[Sat Mar 18 05:06:05 EDT 2017] Access to the disk on channel (??) is producing I/O errors. Although the array is still redundant, please replace this drive as soon as possible, as it is likely to fail soon.
[Sat Mar 18 05:06:05 EDT 2017] A SATA reset has been performed on one or more of your disks that may have affected the RAID parity integrity. It is recommended that you perform a RAID volume resync from the RAID Settings tab ( accessible in the Volumes page => Volume tab in FrontView ). The resync process will run in the background, and you can continue to use the ReadyNAS in the meantime.
[Sat Mar 18 05:06:06 EDT 2017] Access to the disk on channel (??) is producing I/O errors. Although the array is still redundant, please replace this drive as soon as possible, as it is likely to fail soon.
[Sat Mar 18 06:13:48 EDT 2017] RAID sync started on volume C.
Next morning it was totally hosed
Powered down via power switch
Disk check ran up to 46% and is frozen there. (power button flashing)
I left it for 24 hours still at 46%
I powered down again last night and it ran to 46% and is still there now.
What is my next step? How long do i leave it running? PLEASE HELP!!
Thank you!
- mdgm-ntgrNETGEAR Employee Retired
Is your backup up to date?
Sounds like you could have one or more bad disks.- juakyAspirant
Actually yes i do belive so. I need to double check though but i relly want to see if the nas will come up.
If the filesystem check doesn't progress and remains stuck you could try skipping the volume check (a boot menu option) and downloading your logs and having a look at those.
