bbh03
Nov 13, 2012Aspirant
Firmware upgrade for NV
Hello,
I am trying to upgrade my ReadyNAS NV (original, not NVX, NV+, etc) with P/N RNV1-S2-0000 and Serial 000D-A201-14CC, but cannot find support for this specific model (documentation or manuals, etc). I would like to do this before upgrading to larger disks (currently running two 500GB disks with RAIDiator™ v3.00c1-p2 [1.00a025]. Any help would be appreciated! Also, what is the largest size disk supported once firmware is up to date?
Thanks
Brian
Thanks
Brian
- chirpaLuminaryThe NV can use the same disks as the NV+. So you can reference the NV+ Disk HCL.
The current firmware is 4.1.10. Max disk size is 2TB. - bbh03AspirantThank you! I located the software but when trying to upgrade on the local tab, the "upload and verify image" remains greyed out although the firmware image file is selected. Any ideas? The remote tab cannot locate the server which is why I am trying manually.
- chirpaLuminaryCan you try using Internet Explorer if you aren't already?
Pre-4.1.3 firmware had issues with FireFox and newer browsers: viewtopic.php?f=7&t=19117 - bbh03AspirantWas using safari (all macs here). I tried Firefox and same problem. No ie for Mac so do I need to borrow someone's pc?
- bbh03AspirantDownloaded Opera and was successful. Thanks for your help!
