× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
How do I update Debian Jessie repository sources?
Sandshark
Sensei
OK, I've seen other posts about issues with installing apps.  What I've seen hasn't helped me.  Here is what I see when I do an apt update:
root@Pro2A:~# apt update
Hit:1 http://security.debian.org jessie/updates InRelease
Ign:2 http://mirrors.edge.kernel.org/debian jessie InRelease
Hit:3 http://mirrors.edge.kernel.org/debian jessie Release
Hit:4 https://download.docker.com/linux/debian jessie InRelease
Err:5 http://mirrors.kernel.org/debian jessie Release.gpg
  The following signatures were invalid: KEYEXPIRED 1668891673
Hit:6 https://apt.readynas.com/packages/readynasos 6.10.8 InRelease
Reading package lists... Done
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://mirrors.edge.kernel.org/debian jessie Release: The following signatures were invalid: KEYEXPIRED 1668891673
etc/apt/sources.list contains this:
deb https://apt.readynas.com/packages/readynasos 6.10.8 updates apps main
deb http://mirrors.kernel.org/debian jessie main
deb http://security.debian.org/ jessie/updates main
6.10.8 is replaced with 6.9.6 on units running the long-term stable release.  I also get some stuff about ZeroTier on units with it installed, but it's not on this NAS and isn't common to all.
Based on something I read elsewhere in the forum with regard to Docker, I tried  apt-key adv --keyserver apt.readynas.com --recv-keys, and that seemed to do something:
Executing: /tmp/tmp.OCrjYmplqk/gpg.1.sh --keyserver
apt.readynas.com
But in the end, I get the same error when doing an apt update.
Message 1 of 8
Guru
Re: How do I update Debian Jessie repository sources?
Just wondering if it is possible to make a local copy of the Jessie repository, and point to that instead???
Message 2 of 8
tigerten
Luminary
Message 3 of 8
HuwSy
Guide
Hi
Because Jessie is oldoldstable now Debian won’t renew the expired signing keys. It is possible to ignore signing keys but that’s a different risk that I wouldn’t attempt personally. The other option is to try Jessie updates here
deb http://security.debian.org/debian/ jessie/updates main non-free contrib
Which will only have some of the packages needed where deemed required for security or use stretch here
deb http://deb.debian.org/debian/ stretch main non-free contrib
To get the needed packages but then remove again to make sure you don’t upgrade via stretch which will likely brick the device and need a factory reset.
Message 4 of 8
Sandshark
Sensei
Another user has written a post on creating a local repository: Here-is-how-I-created-a-local-repository-easily.  The image files he talks about are available here:  https://cdimage.debian.org/cdimage/archive/8.11.1/ .  Make sure you get the image for your NAS architecture (amd64 or armel).  I've not done it yet, myself.
Message 5 of 8
HuwSy
Guide
Has anyone managed anything newer than Jessie on the x86 hardware? Or another os entirely as long as it still gets ssh, docker and raid 5?
Message 6 of 8
Sandshark
Sensei
Google will find you some who have, though the articles are a bit old.  Doing it on a unit with a video port is certainly much easier than one that does not.  The console output (5 or 3.3V level RS-232 protocol) can be used, but takes extra effort and hardware.
Message 7 of 8
tigerten
Luminary
I would still prefer readyNAS os over bothers. Old but fine.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 4681 views
  • 2 kudos
  • 4 in conversation
Announcements
