laruf's avatar
laruf
Howto install Prestashop
Hi,
Can someone tell me howto install Prestashop on a readynas
I've followed the howto from the Prestashop website. I've looked on the web but can't find anything which could help me install it.
Regards
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    You'd need to install a PHP add-on (probably PHP 5.3) and if you don't use Photos II, you'd also need to install the MySQLON add-on. You may also wish to install the PHPMyAdmin community add-on. You may need to configure some things in Frontview as well (e.g. FTP) if you haven't already. Then I guess I'd follow the instructions from the Prestashop website and see if you can get it to install.
    Welcome to the forum!
  • Hi,
    Currently I've already installed :
    1. Enable SSH Root
    2. PHP 5
    3. Mysql On
    4. PHPMyAdmin
    5. Copy Prestashop files in a share
    My problem is that when i try to install using this link http://my_readynas_ip/my_web_share/install or http://my_readynas_ip/install, i get a login windows on which i can't login. even with my root and password account.
    Any idae on how to correctly install Prestashop ?
    I own a ReadyNas Ultra 2
    Thanks in advance.
    Regards
ProSupport for Business
