mjp08123's avatar
mjp08123
Issues with Softether VPN server
Hi all,
wondering if anyone can help me establish a connection to my softether VPN? Running a RN104 here. As far as I'm concerned, I've opened the correct ports on my router and configured everything correctly, but I seem to be having issues getting on - here is an extract from my log at the moment of connection showing the issues:
2014-09-27 08:21:50.036 IPsec Client 6 (192.168.0.1:500 -> 192.168.0.2:500): A new IPsec client is created.
2014-09-27 08:21:50.036 IPsec IKE Session (IKE SA) 4 (Client: 6) (192.168.0.1:500 -> 192.168.0.2:500): A new IKE SA (Main Mode) is created. Initiator Cookie: 0x61827B7BB6ED3B37, Responder Cookie: 0x4CFE123F22D55341, DH Group: MODP 1024 (Group 2), Hash Algorithm: SHA-1, Cipher Algorithm: AES-CBC, Cipher Key Size: 256 bits, Lifetime: 4294967295 Kbytes or 28800 seconds
2014-09-27 08:21:50.177 IPsec Client 6 (192.168.0.1:4500 -> 192.168.0.2:4500): The port number information of this client is updated.
2014-09-27 08:21:50.177 IPsec IKE Session (IKE SA) 4 (Client: 6) (192.168.0.1:4500 -> 192.168.0.2:4500): This IKE SA is established between the server and the client.
2014-09-27 08:21:51.200 IPsec IKE Session (IKE SA) 4 (Client: 6) (192.168.0.1:4500 -> 192.168.0.2:4500): The client initiates a QuickMode negotiation.
2014-09-27 08:21:51.200 IPsec ESP Session (IPsec SA) 3 (Client: 6) (192.168.0.1:4500 -> 192.168.0.2:4500): A new IPsec SA (Direction: Client -> Server) is created. SPI: 0x3D7DEFB1, DH Group: (null), Hash Algorithm: SHA-1, Cipher Algorithm: AES-CBC, Cipher Key Size: 256 bits, Lifetime: 4294967295 Kbytes or 28800 seconds
2014-09-27 08:21:51.200 IPsec ESP Session (IPsec SA) 3 (Client: 6) (192.168.0.1:4500 -> 192.168.0.2:4500): A new IPsec SA (Direction: Server -> Client) is created. SPI: 0x9A79DBE, DH Group: (null), Hash Algorithm: SHA-1, Cipher Algorithm: AES-CBC, Cipher Key Size: 256 bits, Lifetime: 4294967295 Kbytes or 28800 seconds
2014-09-27 08:21:51.200 IPsec ESP Session (IPsec SA) 3 (Client: 6) (192.168.0.1:4500 -> 192.168.0.2:4500): This IPsec SA is established between the server and the client.
2014-09-27 08:21:52.303 IPsec Client 6 (192.168.0.1:4500 -> 192.168.0.2:4500): The L2TP Server Module is started.
2014-09-27 08:21:52.363 L2TP PPP Session [192.168.0.1:1701]: A new PPP session (Upper protocol: L2TP) is started. IP Address of PPP Client: 192.168.0.1 (Hostname: "anonymous"), Port Number of PPP Client: 1701, IP Address of PPP Server: 192.168.0.2, Port Number of PPP Server: 1701, Client Software Name: "L2TP VPN Client", IPv4 TCP MSS (Max Segment Size): 1314 bytes
2014-09-27 08:21:52.383 On the TCP Listener (Port 0), a Client (IP address 192.168.0.1, Host name "SkyRouter.Home", Port number 1701) has connected.
2014-09-27 08:21:52.383 For the client (IP address: 192.168.0.1, host name: "SkyRouter.Home", port number: 1701), connection "CID-5" has been created.
2014-09-27 08:21:52.383 SSL communication for connection "CID-5" was started. The encryption algorithm name is "(null)".
2014-09-27 08:21:52.403 [HUB "Spectrum"] The connection "CID-5" (IP address: 192.168.0.1, Host name: SkyRouter.Home, Port number: 1701, Client name: "L2TP VPN Client", Version: 1.00, Build: 9371) is attempting to connect to the Virtual Hub. The auth type provided is "External server authentication" and the user name is "MPLUMMER".
2014-09-27 08:21:52.403 [HUB "Spectrum"] Connection "CID-5": Successfully authenticated as user "MPLUMMER".
2014-09-27 08:21:52.403 [HUB "Spectrum"] Connection "CID-5": The new session "SID-MPLUMMER-[L2TP]-3" was created. (IP address: 192.168.0.1, Port number: 1701, Physical underlying protocol: "Legacy VPN - L2TP")
2014-09-27 08:21:52.403 [HUB "Spectrum"] Session "SID-MPLUMMER-[L2TP]-3": The parameter was set. Max number of TCP connections: 1, Use of encryption: Yes, Use of compression: No, Use of Half duplex communication: No, Timeout: 20 seconds.
2014-09-27 08:21:52.403 [HUB "Spectrum"] Session "SID-MPLUMMER-[L2TP]-3": VPN Client details: (Client product name: "L2TP VPN Client", Client version: 100, Client build number: 9371, Server product name: "SoftEther VPN Server (32 bit)", Server version: 100, Server build number: 9371, Client OS name: "L2TP VPN Client", Client OS version: "-", Client product ID: "-", Client host name: "anonymous", Client IP address: "192.168.0.1", Client port number: 1701, Server host name: "192.168.0.2", Server IP address: "192.168.0.2", Server port number: 1701, Proxy host name: "", Proxy IP address: "0.0.0.0", Proxy port number: 0, Virtual Hub name: "Spectrum", Client unique ID: "BA96BF178CC21830A410DEC203EFAE00")
2014-09-27 08:21:52.423 L2TP PPP Session [192.168.0.1:1701]: Trying to request an IP address from the DHCP server.
2014-09-27 08:21:57.436 L2TP PPP Session [192.168.0.1:1701]: Acquiring an IP address from the DHCP server failed. To accept a PPP session, you need to have a DHCP server. Make sure that a DHCP server is working normally in the Ethernet segment which the Virtual Hub belongs to. If you do not have a DHCP server, you can use the Virtual DHCP function of the SecureNAT on the Virtual Hub instead.
2014-09-27 08:22:03.623 L2TP PPP Session [192.168.0.1:1701]: The VPN Client sent a packet though an IP address of the VPN Client hasn't been determined.
2014-09-27 08:22:03.623 L2TP PPP Session [192.168.0.1:1701]: A PPP protocol error occurred, or the PPP session was disconnected.
2014-09-27 08:22:03.884 [HUB "Spectrum"] Session "SID-MPLUMMER-[L2TP]-3": The session was terminated. The statistical information is as follows: Total outgoing data size: 0 bytes, Total incoming data size: 1320 bytes.
2014-09-27 08:22:03.924 Connection "CID-5" terminated by the cause "The VPN session was deleted. It is possible that either the administrator disconnected the session or the connection from the client to the VPN Server was disconnected." (code 11).
2014-09-27 08:22:03.924 Connection "CID-5" was terminated.
2014-09-27 08:22:03.924 The connection with the client (IP address 192.168.0.1, Port number 1701) was disconnected.
Anyone have any ideas?
Thanks!
Matt
1 Reply
  • I think the problem is on client side config, as you can see on logs, the client cant get valid IP:
ProSupport for Business
