JoniSMAC's avatar
JoniSMAC
Follower
Apr 11, 2013
Missing shares detected
Hostname: NAS
Model: ReadyNAS NVX Business Edition [X-RAID2]
Serial: 22M193RN000D6
Firmware: RAIDiator 4.2.22
Memory: 1024 MB [6-6-6-24 DDR2]
IPv4 address: 1+2: 192.168.10.114
Volume C: Offline, X-RAID2, 4 disks, 100% of 4634 GB used
The used space should only be around 25%
During a routine scheduled "Volume consistency check" our ReadyNAS sent these email messages:
1-Volume consistency check failed for Volume C
The on-line filesystem consistency check detected problems with your data volume. Please reboot the system with the volume scan checkbox enabled to do a full filesystem consistency check and repair.
2-Missing shares detected
The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume.
media
backup
3-Volume scan found errors that it could not easily correct. Please ensure that you have current backups of all valuable data before performing a full volume scan by rebooting the NAS through Frontview with the volume scan option enabled.
***** File system check performed at Sun Mar 24 14:01:59 PDT 2013 *****
fsck 1.41.14 (22-Dec-2010)
/dev/c/c: Superblock has an invalid journal (inode 8).
CLEARED.
*** ext3 journal has been deleted - filesystem is now ext2 only ***
/dev/c/c: One or more block group descriptor checksums are invalid. FIXED.
/dev/c/c: Group descriptor 0 checksum is invalid.
/dev/c/c: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
(i.e., without -a or -p options)
4-Missing shares detected
media
backup
We are unable to access any share at this point, please advise on what to do next.
Thanks
1 Reply
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Contact NetGear tech support and post your case number. You will need to try to get your case escalated to L3.
ProSupport for Business
