eton's avatar
eton
Luminary
Jan 12, 2015
Monitor rsync daemon?
Is there some way to view what rsync is doing during a backup job when rsync is running as a daemon? Maybe something similar to rsync -v, to monitor what files are being copied.
  • I would second that capability.
    The current logging is not robust enough for our needs.
    Truncated log files are a not acceptable.
    A check box for summary vs detailed would be nice for those who don't want the whole thing.
  • No help?
    Let me rephrase.
    I there a way to "connect" to an active rsync process and display what it's doing right now? Similar to -v (or -vv) on non daemon rsync commands.
  • If you look at the (truly hideous Perl code) /frontview/bin/backup then you can modify the command that's being executed. I would suggest teeing to a temporary log file.
    Thanks abickerton! I've missed that one.
    That file might need further scrutiny.
ProSupport for Business
