Fandango522
Jul 08, 2018Aspirant
NAS 104 Detected increasing uncorectable error count
I have had a NAS 104 for about 4 years and until now had no problems. Recently I began receiving email warnings about increased uncorectable error counts and that it was a sign of impending drive failure. I removed the drive and replaced with a new drive however after only a few days am receiving the same warnings.
Does anyone have a reason to why this would be?
FYI the drives are green showing healthy.
cheers
Can you post the SMART stats? If you download the log zip file from the web UI, you will find them in disk_info.log
Also,
- what drive model are you using?
- what firmware are you running?
There are three possibilities:
- The new drive also just happened to be defective/marginal
- There is something wrong with the NAS SATA interface or perhaps the PSU
- There is a driver issue of some sort in the NAS software
The last possibility only applies for some errors - for instance command timeouts might be caused by a driver issuing a bad command. Uncorrectable disk errors, reallocated sectors, or pending sectors are all detected and monitored by the drive firmware, and the NAS software can't cause them.
They will show green until a drive actually fails. There is no "still working but at risk" color.
- Fandango522Aspirant
Hi, thanks for the reply, I have attached the SMART log.
Firmware was updated recently to 6.9.3
New disk is - Seagate Ironwolf 4tb NAS drive.
Cant seem to upload txt file so have saved as pdf. Layout seems off but might be ok for someone that knows what to look for.
If no good let me know and Ill try another way.
Thanks
The errors on both disks are somewhat different, and both point to the drive itself, and not the NAS.
The older drive (Z302D20C) was installed in Nov 2014, and had no issues until June 18th of this year - when it began generating uncorrectable read errors/pending sectors and ATA errors. When you replaced it about 2 weeks later, it had about 31 uncorrectable read errors, but 344 ATA errors. Given the rapid climb in errors, I think you were wise to replace it. Unfortunately it is out of warranty (3 years for the ST4000VN000).
The new drive (ZGY1GDFS) has 104 reallocated sectors and 16 uncorrectable read errors/pending sectors. The reallocated sectors and uncorrectable read errors/pending sectors are being reported by the drive firmware itself, not the NAS. These errors happened very quickly after installation - the first problem showing up about 10 hours after installation. In my opinion you were shipped a defective drive.
Personally I won't use a disk if the sum of reallocated+pending sectors is more than 50(and if I see any reallocated sectors or pending sectors in a newly purchased disk, I return/exchange it with the seller.
So I'd definitely exchange it. If you RMA it to seagate, they will give you a recertified replacement, and you will lose most of the warranty.
