teho59's avatar
teho59
RN 516 startup - loop at welcome
I am trying to start my NAS and it shows the first text "Netgear storage welcome", then the OK button with the arrow ring shows up. Half a second everyting disappers and after 2-3 second it repeats. This is going on and on, fans are at full speed.
I have tried to press the reset button, both alone and when I power on. No difference.
The NAS has been on for several months without problems. I had to shut it down from remote during some maintenance in the bulding and it has been off for 3 weeks. I had the latest software installed I believe.
What to do, how can I make it start properly?
- Terje
  • An update:
    I talked to support on the phone that guided me through a couple of things to try.
    I tried to boot the NAS when holding the reset-button pressed without luck. This should lead to the boot menu. Then a USB-stick was created and inserted to the NAS. The NAS should now boot from the USB-stick but that did not happen. Nothing helped and the conclusion is that there is something wrong with the case. I have tried to boot without the disks and that made no difference either.
    I will get a replacement. The support guy was patient and did a good job to guide me. Excellent support!
  • I'm having the same issue with mine so I'm curious to see what people suggest.  Whatever you do, don't open the cover if someone suggests reseating the memory or the battery as it will void the warranty (if you still have one).  That's what happened to me and now they won't even consider replacing my unit.  Good luck, I'll be watching closely in hopes someone has the right answer!
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi teho59
    Welcome to the Community!
    What firmware are you running? Have you tried checking with RAIDar? It should show you the status of the NAS when booting.
    You can download RAIDar here.
    Regards
    • Hi,
      I am unable to see the firmware, it "restarts" after 2-3 seconds. See the videofile attached. There you see the two repeats but it is going on and on.
      I did an firware update about 6-8 weeks ago if I remember correct. I think I am on the last or second last version.
      Link to videofile, was not able to insert in this reply: http://www.hopso.no/IMG_0364.MOV
      • mdgm-ntgr's avatar
        mdgm-ntgr
        Are you the original purchaser of the unit from an authorised reseller and was it purchased less than 5 years ago?
  • An update:
ProSupport for Business
