Andrew_Oz
Mar 08, 2020Aspirant
RN10400 Power supply failure - flashing green light
Hi,
My power supply has failed - the green light flashes about once per second and the NAS powers up for that split second and then goes off again. I suspect it's the power supply. It has a special connection at the NAS end so I'm guessing I can't easily by one from an electrical dealer.
Do Netgear have spare parts which I can purchase or does anyone have a spare one I can buy from them?
Thanks
Andrew
- Marc_VNETGEAR Employee Retired
Welcome to the Community!
If it's the adapter you need you can purchase a 4-PIN DIN AC Adapter (12V, 7A External 90W; input 100-240V AC, 50-60Hz) on Amazon or other online stores.
If it's the Internal Power Supply on the RN104 spare parts are not available from NETGEAR, the best thing to do would be to purchase a refurbished RN104 online or upgrade to a newer NAS if possible. If your RN104 was purchased under 3 years RMA can be provided to you. You just need to register it at my.netgear.com and create a case.
You will also have to provide the Proof of Purchase upon requesting for RMA.
HTH
Regards
- Andrew_OzAspirant
Hi Marc,
Thanks for your reply. The green light on the adapter flashes so I'm assuming it's that which has expired. If so, is this what you mean as far as a replacement goes?
Thanks
