Bartleby's avatar
Bartleby
ReadyNAS 102 Factory Reset not accepting 'Password'
Hadn't been using my ReadyNAS 102 for a while (18 months) and couldn't find the  correct username/password to set it up again (Mac Keychain versions were incorrect for some reason) so tried a reset, OS first and then a factory reset. The NAS refuses to recognise the standard 'admin'/'password' login details in either computer connection or through Raidar.
Is there any way round this? I've now tried factory rests a few times but there's no difference.
Any suggestions appreciated.
  • StephenB's avatar
    Are you certain this is an RN102? (I ask because you selected the RND2110 Duo as your model, which is a very different platform).  The Duo uses netgear1 as the default password.
    Assuming it is an RN102 - the most likely cause is that the factory reset didn't "take".  Did you use the procedure in the hardware manual?  It's on pages 20-21 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
    The boot menu options for the old Duo are different btw.
    • Bartleby's avatar
      Bartleby
      Thanks for that.
      Yes it is a 102 and about an hour after posting I managed to stumble on on the 'netgear1' password requirement. This was the problem rather than a failure in the reset. Even so, I thoroughly appreciate the effort you've gone to.
      As for the RND 2110, that was selected in error. Sorry for any confusion.
      Cheers
      • StephenB's avatar
        That means you actually don't have an RN102.  Only legacy NAS running 4.1.x and 4.2.x firmware use netgear1 as their default admin password.  OS 6 systems like the RN102 use password.  Can you post a screenshot of the home page in the web admin UI?
ProSupport for Business
