aks-2's avatar
aks-2
Apprentice
Aug 26, 2023
ReadyNAS 214 data corruption issue
I am seeing a very strange behaviour that results in corrupted files. My NAS (ReadyNAS 214) has been stable for years, until recently I found a single file had an error revealed via the logs following a scrub. I recoved that from a backup.
Over the past two days, I have noticed various newly written files appear fine, but after 'a bit of time', they become corrupted. Yes, weird I know. This has happened with edited Excel (xlsx) and non-edited .jpg and PDF files. Not all files going to the NAS are affected.
To isolate the issue:
  • I scanned my PC in case of a virus. Nothing found.
  • Created a checksum file, then copied the files to the NAS. Reread the checksums and all appears good.
  • A variable time later, re-check checksums. Results bad.
  • The time to going bad is immediate if I re-copy a file within the NAS folder, i.e. CTRL-C / CTRL-V, then check the checksums, and both the original and copy become corrupted.
  • I initially noticed this issue with photos as previews no longer showed, but repeated with xls and pdf.
  • I shutdown my PC in case it was the cause in some way, e.g. undetected virus.
  • I then tried from my wifes PC and was able to recreate the corrupting of files, almost at will.
  • I'm now convinced it's a NAS problem, rather than a PC problem, but maybe I am wrong!
So, I dived in to the logs and found quite a few lines like the following line in kernel.log:
Aug 26 17:54:53 NETDISK kernel: BTRFS error (device md124): bdev /dev/md127 errs: wr 95, rd 333, flush 0, corrupt 0, gen 0
Which of course looks bad, and is probably why I am getting corrupted files.
Any ideas how I identify the root cause, and fix this, as right now I cannot trust anything writen to the NAS?
Luckily, I think I caught this early and have other copies of the files, or can re-create any lost data easily.
  • StephenB's avatar
    Are you also seeing disk errors?  Or just btrfs errors on the RAID array?
    • aks-2's avatar
      aks-2
      Apprentice
      No disk errors in the logs, or reported in the dashboard logs page.
      • StephenB's avatar
        Have you run the disk test from the volume settings wheel lately?
        One option is to do a factory reset (or destroy/recreate the volume), and see if the sync succeeds. Are you using X-RAID?  Or FlexRAID with multiple volumes.
ProSupport for Business
