wolfgangcc
Mar 09, 2018Aspirant
ReadyNAS 516 not showing Shares in Frontview (GUI)
I'm running Firmware 6.9.2 and ran into an issue months ago were i had to recover the NAS. Since the recovery I havent been able to see most of my shares in web interface. If I map the drive i get the following ....the image after shows my web interface.
I've triued edditing the /etc/frontview/samba/Shares.conf file to add "guest ok = 1" also looked around in samba in ssh and cant seem to find the issue. I wouldn't be to concerned about the web interface but it those additional folders are no longer available to both of my TV's when browsing media shares. I really need to get that capability back. Would be greatfull for any ideas.
Thanks!
Chris
One thing you could try is
- rename one of the public share folders (subvolume)
- create a new share with the original name
- delete the new subvolume with btrfs subvolume delete -c \data\sharename
- rename the original public share folder to the original name.
If that restores the share to the Web UI, then you could repeat that for the rest of them.
- mdgm-ntgrNETGEAR Employee Retired
That's one way of dealing with it.
Another way would be to try to fix the config files (there's a way that needs to be handled).
