MarkJPearce's avatar
MarkJPearce
ReadyNas 104 - Network overrun errors
Hi,
I have a ReadyNAS 104 running at firmware v 6.7.4 and I have recently started noticing the following errors when running journalctl:
Jun 16 13:59:39 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=640
Jun 16 14:03:37 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=512
Jun 16 14:05:18 GlassNib-NAS clamd[3759]: SelfCheck: Database status OK.
Jun 16 14:09:01 GlassNib-NAS CRON[5274]: pam_unix(cron:session): session opened for user root by (uid=0)
Jun 16 14:09:01 GlassNib-NAS CRON[5278]: (root) CMD (  [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean)
Jun 16 14:09:05 GlassNib-NAS CRON[5274]: pam_unix(cron:session): session closed for user root
Jun 16 14:11:49 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=512
Jun 16 14:15:18 GlassNib-NAS clamd[3759]: SelfCheck: Database status OK.
Jun 16 14:16:12 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=448
Jun 16 14:16:12 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=1024
Jun 16 14:16:12 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=1152
Jun 16 14:16:14 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=512
Jun 16 14:16:16 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=1024
Jun 16 14:16:34 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=512
Jun 16 14:16:42 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=144
Jun 16 14:16:47 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=1024
Jun 16 14:17:01 GlassNib-NAS CRON[5337]: pam_unix(cron:session): session opened for user root by (uid=0)
Jun 16 14:17:01 GlassNib-NAS CRON[5341]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Jun 16 14:17:02 GlassNib-NAS CRON[5337]: pam_unix(cron:session): session closed for user root
Jun 16 14:17:04 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=1024
Jun 16 14:17:18 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=440
Jun 16 14:17:28 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=512
Jun 16 14:17:28 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=1024
Jun 16 14:17:28 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=400
Jun 16 14:17:29 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=272
Jun 16 14:17:29 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=1024
Jun 16 14:17:29 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=1408
Jun 16 14:17:29 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=504
Jun 16 14:17:29 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=1280
Jun 16 14:17:29 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=144
Jun 16 14:17:29 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0d830000 (overrun error), size=16
Jun 16 14:17:33 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=1024
Jun 16 14:17:38 GlassNib-NAS kernel: mvneta d0074000.ethernet eth1: bad rx status 0f830000 (overrun error), size=1024
I have re-installed the OS, due to another issue yesterday which was resolved by the re-install, but I can't seem to get passed this one.  I ahve not touched the MTU on the network interfaces, it is set to the standard 1500 on both interfaces.
I am running both Windows and mac computers at home and also have a remote back-up over Rsync coming into this ReadyNAS, but the errors appear during normal operation as well as during the Rsynch backup.  I ahve also noticed that my Timemachine backups of my mac keep failing and telling me that they have to start a new backup on a regular basis, not sure if this is connected or not?
Any suggestions would be gratefully received,
Mark
1 Reply
  • StephenB's avatar
    Overall, an rx overrun in the NAS means that the NAS itself isn't able to keep up with the data it is receiving.
    Try turning on ethernet flow control in your PCs (both tx and rx).  If you have managed or smart switches, look for flow control settings in them also.
    These shouldn't do damage, as TCP will retransmit.
ProSupport for Business
