Xineru
May 17, 2016Follower
ReadyNas 104
Hola, tengo un ReadyNas 102 y he adquirido un ReadyNas 104, quiero pasar los dos discos Raid 0 al nuevo Nas sin perder los datos, ¿es posible? ¿alguien conoce una forma sencilla de hacerlo?
Puedes sacar los dos discos RAID 0 del RN102 y ponganlos en el RN104; pero no hay posibilidades a expandir tu RAID a 4 discos; puedes hacer un volume nuevo si quieres.... RAID 0 no tenga redundancia.
Con tu RN102 y RN104 apagado, tome los discos de RN102 y los situara en RN104. Iniciar el chasis. Debes estar trabajando.
Espero que esto ayude!
- JennCNETGEAR Employee Retired
Hello Xineru,
Are you trying to move the disks from RN102 to RN104? If so, and the existing volume in RN102 is RAID 0 then that is okay to move to the RN104, same order. If the existing volume is XRAID then you need to backup the data because switching to FlexRAID needs formatting the disks and this will delete the data stored to the volume. Moreover, we always recommend to always have full backup of the data.
Welcome to the community!
Hello Xineru,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- kohdeeNETGEAR Expert
