seegersa's avatar
seegersa
Rsync 'failed: Read-only file system (30)' error?
Trying to backup to an external EXT3 formatted USB drive.
Worked fine in the past ... suddenly I'm receiving this error?
Thanks for ANY input!!
INCREMENTAL Backup started. Fri Jul 20 07:52:56 PDT 2012
Job: 001
Protocol: rsync
Source: [media]/Music
Destination: localhost::USB_HDD_1/media/Music
sending incremental file list
.DS_Store
SyncToy_60eca71e-438c-42ab-bfaa-a11c1b78212f.dat
rsync: writefd_unbuffered failed to write 4 bytes to socket [sender]: Connection reset by peer (104)
rsync: recv_generator: mkdir "/media/Music/.AppleDouble" (in USB_HDD_1) failed: Read-only file system (30)
*** Skipping any contents from this failed directory ***
rsync: connection unexpectedly closed (43 bytes received so far) [sender]
rsync error: error in rsync protocol data stream (code 12) at io.c(605) [sender=3.0.9]
Backup failed. Fri Jul 20 07:53:04 PDT 2012.
Reason for failure:
Error encountered copying data from source path /media/Music ==> localhost::USB_HDD_1/media/Music due to unknown reason. Please see log.
1 Reply
  • Resolved ... by resetting ownership and permission to the share.
ProSupport for Business
