- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Spinning up shortly after each Spinning down
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just bought a new ReadyNAS 214 and updated to latest firmware (6.7.5). I setup spin-down (5 minutes, all the time) as I rarely use it (mainly only for storage and back-up purpose). However, I noticed that the disk is running all the time. I checked the log, and found that it always spinning up shortly (5~20 seconds) after spinning down.
Here is the latest log (with disk information, only 1 disk installed)
Aug 15 05:26:12 ReadyNAS noflushd[31164]: Enabling spindown for disk 1 [sda,0:0:ST8000VN0022-2EL112:[Serial]:SC61:7200]
Aug 15 05:32:08 ReadyNAS noflushd[31164]: Spinning down disk 1 (/dev/sda).
Aug 15 05:32:16 ReadyNAS noflushd[31164]: Spinning up disk 1 (/dev/sda) after 0:00:05.
Aug 15 05:37:23 ReadyNAS noflushd[31164]: Spinning down disk 1 (/dev/sda).
Aug 15 05:37:31 ReadyNAS noflushd[31164]: Spinning up disk 1 (/dev/sda) after 0:00:05.
Aug 15 05:42:38 ReadyNAS noflushd[31164]: Spinning down disk 1 (/dev/sda).
Aug 15 05:42:46 ReadyNAS noflushd[31164]: Spinning up disk 1 (/dev/sda) after 0:00:05.
Aug 15 05:48:34 ReadyNAS noflushd[31164]: Spinning down disk 1 (/dev/sda).
Aug 15 05:48:42 ReadyNAS noflushd[31164]: Spinning up disk 1 (/dev/sda) after 0:00:05.
Aug 15 05:55:21 ReadyNAS noflushd[31164]: Spinning down disk 1 (/dev/sda).
Aug 15 05:55:39 ReadyNAS noflushd[31164]: Spinning up disk 1 (/dev/sda) after 0:00:15.
Aug 15 06:00:45 ReadyNAS noflushd[31164]: Spinning down disk 1 (/dev/sda).
Aug 15 06:01:03 ReadyNAS noflushd[31164]: Spinning up disk 1 (/dev/sda) after 0:00:15.
Aug 15 06:11:07 ReadyNAS noflushd[31164]: Spinning down disk 1 (/dev/sda).
Aug 15 06:11:30 ReadyNAS noflushd[31164]: Spinning up disk 1 (/dev/sda) after 0:00:20.
Aug 15 06:16:36 ReadyNAS noflushd[31164]: Spinning down disk 1 (/dev/sda).
Aug 15 06:16:54 ReadyNAS noflushd[31164]: Spinning up disk 1 (/dev/sda) after 0:00:15.
Aug 15 06:21:57 ReadyNAS noflushd[31164]: Spinning down disk 1 (/dev/sda).
Aug 15 06:22:15 ReadyNAS noflushd[31164]: Spinning up disk 1 (/dev/sda) after 0:00:15.
Aug 15 06:27:18 ReadyNAS noflushd[31164]: Spinning down disk 1 (/dev/sda).
Aug 15 06:27:36 ReadyNAS noflushd[31164]: Spinning up disk 1 (/dev/sda) after 0:00:15.
Aug 15 06:32:39 ReadyNAS noflushd[31164]: Spinning down disk 1 (/dev/sda).
Aug 15 06:32:57 ReadyNAS noflushd[31164]: Spinning up disk 1 (/dev/sda) after 0:00:15.
Aug 15 06:38:01 ReadyNAS noflushd[31164]: Spinning down disk 1 (/dev/sda).
Aug 15 06:38:19 ReadyNAS noflushd[31164]: Spinning up disk 1 (/dev/sda) after 0:00:15.
Aug 15 06:43:22 ReadyNAS noflushd[31164]: Spinning down disk 1 (/dev/sda).
Aug 15 06:43:40 ReadyNAS noflushd[31164]: Spinning up disk 1 (/dev/sda) after 0:00:15.
Aug 15 06:48:44 ReadyNAS noflushd[31164]: Spinning down disk 1 (/dev/sda).
Aug 15 06:49:02 ReadyNAS noflushd[31164]: Spinning up disk 1 (/dev/sda) after 0:00:15.
No app installed (used to install QBitTorrent but uninstalled). SMB, AFP, ReadyDLNA, UPnP, HTTP, HTTPS are enabled (all by default). Saw another thread of the issue caused by IPv6 so IPv6 is disabled but not helpful. The disk is pretty empty at this time (485.8GB used).
Any suggestion? Is there any way to debug myself, or should I send the log to someone?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just want to close this topic as the issue is solved.
I contacted customer service, and instructed by engineer to install 6.8.1-RC1, which version fixed the issue.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Spinning up shortly after each Spinning down
If Antivirus is enabled, you might try disabling it and see if that makes a difference.
Does it ever stay spun down for more than a few seconds?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, AntiVirus is not enabled.
No. I enabled spindown since Aug12, 22:19:14, and I checked through the log, Best I could get is 25 seconds (3 times), and usually 15 seconds (278 times), and 5 seconds (234 times).
- Mark as New
- Bookmark
- Subscribe
- Permalink
You haven't said much about your network configuration, can we assume you've isolated the ReadyNAS and 'listened' to it or watched the display? How about pulling the network cable, does it stay spun down - I expect it will?
- Mark as New
- Bookmark
- Subscribe
- Permalink
After upgraded to 6.8.0, the issue is still not solved.
Also noticed this in another log file.
[17/08/17 09:07:52] event_push.c:189 rnutil readynasd <xs:add-s resource-type="Lcd">
<lcd expiration="1502986132" priority="1" key="478" string="Disks sleeping.."/></xs:add-s>
0 0 ==> ec=0
[17/08/17 09:08:10] event_push.c:189 rnutil readynasd <xs:add-s resource-type="Lcd">
<lcd expiration="1502986100" priority="1" key="478" string="Disks waking..."/></xs:add-s>
0 0 ==> ec=0
[17/08/17 09:13:14] event_push.c:189 rnutil readynasd <xs:add-s resource-type="Lcd">
<lcd expiration="1502986454" priority="1" key="478" string="Disks sleeping.."/></xs:add-s>
0 0 ==> ec=0
[17/08/17 09:13:32] event_push.c:189 rnutil readynasd <xs:add-s resource-type="Lcd">
<lcd expiration="1502986422" priority="1" key="478" string="Disks waking..."/></xs:add-s>
0 0 ==> ec=0
[17/08/17 09:18:36] event_push.c:189 rnutil readynasd <xs:add-s resource-type="Lcd">
<lcd expiration="1502986776" priority="1" key="478" string="Disks sleeping.."/></xs:add-s>
0 0 ==> ec=0
[17/08/17 09:18:54] event_push.c:189 rnutil readynasd <xs:add-s resource-type="Lcd">
<lcd expiration="1502986744" priority="1" key="478" string="Disks waking..."/></xs:add-s>
0 0 ==> ec=0
Not sure if this means anything.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tested, no, without network, still can only spin down for 15 seconds
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry, I don't have a RN214, but it should be easy for someone that does to check if their unit can spin down and stay that way for a while.... this will verify if it's a generic problem or some configuration issue with your setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
