Melton_Pereira
Nov 23, 2020Aspirant
Unable to Reset Password for ReadyNas 3220
Hi All,
Can any one help me as I am not able to reset the password in my readyNAS Device under admin account .
Whenever I try to reset it showing an error "Failed to set password recovery method Error in setAdminPassword recovery "
I am using Firmware 6.10.3
1 Reply
You can alternatively do an OS reinstall using the boot menu. That will reset the password to password.
The OS reinstall has two other side effects - it will
- reset the network config to the factory default (DHCP, no bonding)
- disable quota on the volume settings wheel
