joblackk
Nov 02, 2015Aspirant
Veem with ReadyNAS 4220
I am about to change our backup storation solution for our virtualized environmnet. I have a few options but one that seems more suited for us is to marry the veem backup with a ReadyNAS 4220. I have about 11 VMs that i need backed up totaling about 8T of space. I am was hoping i could get some information on this particula setup related to performance and setup. If anyone has experience with this setup, i would greatly appreciate any info.
Thanks in advance.
- joblackkAspirant
Shocked that no one has done this and can shed some light on this subject.
- kohdeeNETGEAR Expert
Hi. I have lots of experience running Veeam against ReadyNAS OS 6.
My recommendation is create a thick iSCSI LUN no larger than 80% of the total volume space. Turn off bit rot protection, turn off snapshots, turn off sync writes. Mount the iSCSI LUN to your machine running Veeam.
Only use the NAS for Veeam and not other backups.
Schedule volume maintenance: defrag for Saturday mornings and balance for Sunday mornings to keep the file system healthy. Make sure these run when the unit is not doing backups.
- joblackkAspirant
Thanks much for your reply. I was under the impression that altought the new appliances don't have LUN size limiations, the local OS will not allow larger sizes then 8T. The one I am looking is the 3220S series readynas. I plan on using the readyNAS just for DR. However, I have a fileserver that i need to keep several weeks of backup. I know Veem does granulary backup but will it sync correctly? And finally, sounds like a full time job to maintain the appliance for a DR solution. Can you provide more information as to why I should warry about the volume maintenance and system health? I do it anyway with my vcenter but I was hoping for more of a "set it an forget it" option.
Thanks much for your help on this.
