Micmap's avatar
Micmap
Volume doesn't resync automatically after replacing hdd
Ok please help, I have a readynas rn314 with an expansion unit eda500.
One of the disks of the raid5 volume in the expansion unit failed the disk test, so I thought it would be a good idea to change the disk.
I replaced the failed disk with a new one except it does not automatically start repairing the volume.
https://i.imgur.com/mPQl8Q4.jpg
When I click the replaced disk all the options are not clickable and I'm stuck here. (see screenshot above)
I'm a bit stressed because my volume has no redundancy atm. How to fix this so the volume will add the new disk to the raid5 volume?
  • Sandshark's avatar
    Sandshark
    Sensei - Experienced User
    Did you replace with the same brand of drive?  If not, is it possible that the new drive is just slightly smaller than the originals?
    If that's not it, first try re-bootng.  And if that doesn't help, see if you can toggle off XRAID and have the options become available.  Once the sync is complete, you can toggle back on XRAID (though it doesn't seem to be doing its job).
    • Micmap's avatar
      Micmap
      Ok I did shut down the NAS before replacing the drive. And put in the new drive before booting.
      But apparently that is not the right way to do it, when I booted with the drive removed it started syncing as soon as I hot-plugged the new drive into the nas.
      But I still think the first way I tried should work as well, through the webinterface. It is also not described in the manual how to do this.
      Something like this should be described in detail.
      • StephenB's avatar
        I always recommend hot removal and hot insertion, because then the NAS easily detects the insertion/removal event.  That said, replacing a drive with the NAS powered down should also work. There are some cases where the failure sets the SATA interface down, and of course many just feel uncomfortable with hot insertion.
        Did you try clicking on the new disk?  If so, did that enable the format control on the right of the screen?
ProSupport for Business
