climbguy
Jan 05, 2014Aspirant
WebDAV on a different port
I am already using port 443 for something else.
Is there anyway to change the port HTTPS port to something else? It looks to be greyed out in front view.
I am using a ReadyNAS 516
1 Reply
- Marto731AspirantClimbguy,
I was going through a KB article, which talked about port 443. My current view is that this port number cannot be changed.
http://kb.netgear.com/app/answers/detail/a_id/12255
Our goal with the router is to forward all HTTPS access to this IP address to the ReadyNAS. HTTPS, or numeric port 443, is what is used for encrypted access for WebDAV access.
To forward port 443 on your router to the ReadyNAS, follow the instructions on this link - it will direct you to a site where you can find out how you can forward the HTTPS (port 443) on your router model. If you have done this correctly, you should be able to access FrontView with:
https://external_ip_address/admin
On a separate note, I accept this article from 2009 is out of date, but it will be worked on.
Regards, Marto
