stgeorge
May 04, 2017Guide
ftp refusing connections
Hey all-
I'm curious what the most typical reason is for the standard ftp server loaded on these nas devices to 'refuse connections' ?
Here's the messaging that I'm getting via a filezilla client when trying to connect:
Status: TLS connection established.
Status: Logged in
Status: Retrieving directory listing...
Status: Server sent passive reply with unroutable address. Using server address instead.
Command: MLSD
Error: The data connection could not be established: ECONNREFUSED - Connection refused by server
Thanks for your thoughts
It sounds like you are connecting remotely (over the internet) - is that correct?
If so, you normally need to
- set a much smaller set of passive ports (perhaps 4 per expected simultaneous connection)
- forward the passive port range in your router to the NAS
Did you do those things?
- stgeorgeGuide
Thanks for the help!
I am trying to connect over the WAN (internet), yes. I guess I need a lesson on port forwarding when it comes to ftp.
I do have the default ftp port (21) forwarded to this particular NAS- the one running this ftp server. I've also set ftp to disabled on the share listing, but have enabled certain users (two for read only and one for read/write). I've listed a 10 port range in the admin screens of the NAS / ftp server settings, but hadn't yet forwarded that port range in my router- I'll try that now.
- stgeorgeGuide
I'm beginning to think that my issue is more with FileZilla than it is with my network and/or NAS settings.... I've just tried logging in with an android app called ANDFTP and it works fine.... not sure- maybe my FileZilla version is old or for whatever reason not playing nice with the NAS server...?
