el_patron's avatar
May 02, 2020
how to block admin page from internet access..?
Hi there,
I have installed nextcloud on my readynas and opened it to the internet,
https://myDynDNS-Readynas
with the ports 443 and 80, installed a letsencrypt certificate for that, and can access the login page of nextcloud via
https://myDynDNS-Readynas/nextcloud/index.php/login
but by doing so, also the admin page of the NAS is now accessible from outside with
https://myDynDNS-Readynas/admin
can this somehow be separated, that only the nextcloud page is accessible from outside, but not the admin page..? Is there a smarter way to access the admin page only from the local net..?
Thank you!
    Unfortunately not.
    Do you need port 80 forwarded?  443 would be all you'd need for https.
  • StephenB's avatar
    Unfortunately not.
    • el_patron's avatar
      el_patron
      Tutor
      at least I needed port 80 for getting the initial certificate from letsencrypt. But I think it is not longer needed for the renewal process... I will give it a try.
      • StephenB's avatar
        If you do need it, then you should make sure that http admin access is disabled on system->settings->services->http.
        It would be nice if you could limit https admin access to use only the secondary https port (or only 443).  Either would accomplish your purpose, and would be a pretty easy thing for Netgear to do.  You could put this into the idea exchange - though don't hold your breath waiting for them to get to it.
ProSupport for Business
