davidr1's avatar
davidr1
Luminary
Jul 15, 2017
sensible-editor: select-editor: not found
I have just installed my new 212 unit.
After exiting crontab -e I get this:
"/usr/bin/sensible-editor: 22: /usr/bin/sensible-editor: select-editor: not found"
The contents of crontab save OK and the script is OK at /usr/bin/sensible-editor
How can I stop this happening please?
  • Hey,
    The /usr/bin/sensible-editor script specifies what editor and visual environment to launch per default. It uses the program "select-editor", but that program is not installed on the NAS it seems. Probably because there is no need to since "vi" is the only editor on the NAS - out of the box.
    The error does not matter. It will only occur when editing a program but not specifying the editor to use (such as crontab -e). If you for example did vi /etc/crontab then the error should not occur as you specify the editor to use.
    You can always install the select-editor program to "fix" the error you see,  but there is no need to.
    • davidr1's avatar
      davidr1
      Luminary
      Thanks for your reply Hopchen
      This didn't this happen on my other units. Annoying. I'll try some settings for the default editor.
      Thanks
ProSupport for Business
