powellandy1
Jul 26, 2018Virtuoso
Adding a 4th 10TB drive to a XRAID array on Pro6 6.9.3 (please reassure me)
Hi
I have a Pro6 on 6.9.3 that had 6x6TB in XRAID2 (single redundancy). I've sequentially added 3x10TB and today added the 4th. It appears the disk was used before (something i'll take up with Amazon) so I destroyed the partition and then restarted.
This time on the volume screen lists 3 different RAID groups (never has done before) and the XRAID on the right is grey not green. I have not consciously chosen to remove XRAID as I want, in the future, to swap out the remaining 2 drives.
Can someone tell me what's going on!
Thanks Andy
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md1 : active raid10 sdf2[5] sde2[4] sdd2[3] sdc2[2] sdb2[1] sda2[0] 1569792 blocks super 1.2 512K chunks 2 near-copies [6/6] [UUUUUU] md125 : active raid5 sdd4[7] sde4[0] sdc4[6] sdb4[9] sda4[8] sdf4[1] 9766874560 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/5] [UUUUU_] resync=DELAYED md126 : active raid5 sdd3[9] sdc3[8] sde3[4] sdf3[5] sda3[6] sdb3[7] 19510833920 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/5] [_UUUUU] [>....................] recovery = 0.9% (37969280/3902166784) finish=506.6min speed=127112K/sec md127 : active raid5 sda5[0] sdb5[2] sdc5[1] 7811566336 blocks super 1.2 level 5, 64k chunk, algorithm 2 [3/3] [UUU] md0 : active raid1 sdd1[9] sdc1[8] sde1[4](W) sdf1[5](W) sda1[6] sdb1[7] 4190208 blocks super 1.2 [6/6] [UUUUUU] unused devices: <none> /dev/md/0: Version : 1.2 Creation Time : Thu Feb 13 19:50:28 2014 Raid Level : raid1 Array Size : 4190208 (4.00 GiB 4.29 GB) Used Dev Size : 4190208 (4.00 GiB 4.29 GB) Raid Devices : 6 Total Devices : 6 Persistence : Superblock is persistent Update Time : Thu Jul 26 16:28:09 2018 State : clean Active Devices : 6 Working Devices : 6 Failed Devices : 0 Spare Devices : 0 Name : 33ea2557:0 (local to host 33ea2557) UUID : a425c11d:4b9480fd:8fa2e4ff:906c719b Events : 1964648 Number Major Minor RaidDevice State 9 8 49 0 active sync /dev/sdd1 8 8 33 1 active sync /dev/sdc1 7 8 17 2 active sync /dev/sdb1 6 8 1 3 active sync /dev/sda1 5 8 81 4 active sync writemostly /dev/sdf1 4 8 65 5 active sync writemostly /dev/sde1 /dev/md/data-0: Version : 1.2 Creation Time : Thu Feb 13 19:50:29 2014 Raid Level : raid5 Array Size : 19510833920 (18606.98 GiB 19979.09 GB) Used Dev Size : 3902166784 (3721.40 GiB 3995.82 GB) Raid Devices : 6 Total Devices : 6 Persistence : Superblock is persistent Update Time : Thu Jul 26 16:27:45 2018 State : clean, degraded, recovering Active Devices : 5 Working Devices : 6 Failed Devices : 0 Spare Devices : 1 Layout : left-symmetric Chunk Size : 64K Rebuild Status : 0% complete Name : 33ea2557:data-0 (local to host 33ea2557) UUID : 92b2bc5f:cf375e4b:5dcb468f:89d2bd81 Events : 13331348 Number Major Minor RaidDevice State 9 8 51 0 spare rebuilding /dev/sdd3 8 8 35 1 active sync /dev/sdc3 7 8 19 2 active sync /dev/sdb3 6 8 3 3 active sync /dev/sda3 5 8 83 4 active sync /dev/sdf3 4 8 67 5 active sync /dev/sde3 /dev/md/data-1: Version : 1.2 Creation Time : Tue Nov 24 12:23:49 2015 Raid Level : raid5 Array Size : 9766874560 (9314.42 GiB 10001.28 GB) Used Dev Size : 1953374912 (1862.88 GiB 2000.26 GB) Raid Devices : 6 Total Devices : 6 Persistence : Superblock is persistent Update Time : Thu Jul 26 16:22:46 2018 State : clean, degraded, resyncing (DELAYED) Active Devices : 5 Working Devices : 6 Failed Devices : 0 Spare Devices : 1 Layout : left-symmetric Chunk Size : 64K Name : 33ea2557:data-1 (local to host 33ea2557) UUID : 4010d079:27f07b46:33b86d75:a3989442 Events : 15430 Number Major Minor RaidDevice State 0 8 68 0 active sync /dev/sde4 1 8 84 1 active sync /dev/sdf4 8 8 4 2 active sync /dev/sda4 9 8 20 3 active sync /dev/sdb4 6 8 36 4 active sync /dev/sdc4 7 8 52 5 spare rebuilding /dev/sdd4 /dev/md/data-2: Version : 1.2 Creation Time : Sun Jul 22 21:41:37 2018 Raid Level : raid5 Array Size : 7811566336 (7449.69 GiB 7999.04 GB) Used Dev Size : 3905783168 (3724.85 GiB 3999.52 GB) Raid Devices : 3 Total Devices : 3 Persistence : Superblock is persistent Update Time : Thu Jul 26 16:22:20 2018 State : clean Active Devices : 3 Working Devices : 3 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Name : 33ea2557:data-2 (local to host 33ea2557) UUID : 1530c06e:fec73963:800bf076:2cf6cf0d Events : 5499 Number Major Minor RaidDevice State 0 8 5 0 active sync /dev/sda5 1 8 37 1 active sync /dev/sdc5 2 8 21 2 active sync /dev/sdb5
- powellandy1Virtuoso
Hi
So it hasn't worked - finished resyncing - the volume size hasn't grown and it still shows the RAID groups with XRAID greyed out. What can I do from here??
Tx
Andy
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md125 : active raid5 sde4[0] sdd4[7] sdc4[6] sdb4[9] sda4[8] sdf4[1] 9766874560 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/6] [UUUUUU] md126 : active raid5 sdd3[9] sde3[4] sdf3[5] sda3[6] sdb3[7] sdc3[8] 19510833920 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/6] [UUUUUU] md127 : active raid5 sda5[0] sdb5[2] sdc5[1] 7811566336 blocks super 1.2 level 5, 64k chunk, algorithm 2 [3/3] [UUU] md1 : active raid10 sda2[0] sdf2[5] sde2[4] sdd2[3] sdc2[2] sdb2[1] 1569792 blocks super 1.2 512K chunks 2 near-copies [6/6] [UUUUUU] md0 : active raid1 sdd1[9] sde1[4](W) sdf1[5](W) sda1[6] sdb1[7] sdc1[8] 4190208 blocks super 1.2 [6/6] [UUUUUU] unused devices: <none> /dev/md/0: Version : 1.2 Creation Time : Thu Feb 13 19:50:28 2014 Raid Level : raid1 Array Size : 4190208 (4.00 GiB 4.29 GB) Used Dev Size : 4190208 (4.00 GiB 4.29 GB) Raid Devices : 6 Total Devices : 6 Persistence : Superblock is persistent Update Time : Fri Jul 27 07:39:54 2018 State : clean Active Devices : 6 Working Devices : 6 Failed Devices : 0 Spare Devices : 0 Name : 33ea2557:0 (local to host 33ea2557) UUID : a425c11d:4b9480fd:8fa2e4ff:906c719b Events : 1964650 Number Major Minor RaidDevice State 9 8 49 0 active sync /dev/sdd1 8 8 33 1 active sync /dev/sdc1 7 8 17 2 active sync /dev/sdb1 6 8 1 3 active sync /dev/sda1 5 8 81 4 active sync writemostly /dev/sdf1 4 8 65 5 active sync writemostly /dev/sde1 /dev/md/1: Version : 1.2 Creation Time : Thu Jul 26 16:22:47 2018 Raid Level : raid10 Array Size : 1569792 (1533.00 MiB 1607.47 MB) Used Dev Size : 523264 (511.00 MiB 535.82 MB) Raid Devices : 6 Total Devices : 6 Persistence : Superblock is persistent Update Time : Fri Jul 27 06:30:25 2018 State : clean Active Devices : 6 Working Devices : 6 Failed Devices : 0 Spare Devices : 0 Layout : near=2 Chunk Size : 512K Name : 33ea2557:1 (local to host 33ea2557) UUID : 911b186b:6f606710:81ff18c2:d960e9df Events : 19 Number Major Minor RaidDevice State 0 8 2 0 active sync set-A /dev/sda2 1 8 18 1 active sync set-B /dev/sdb2 2 8 34 2 active sync set-A /dev/sdc2 3 8 50 3 active sync set-B /dev/sdd2 4 8 66 4 active sync set-A /dev/sde2 5 8 82 5 active sync set-B /dev/sdf2 /dev/md/data-0: Version : 1.2 Creation Time : Thu Feb 13 19:50:29 2014 Raid Level : raid5 Array Size : 19510833920 (18606.98 GiB 19979.09 GB) Used Dev Size : 3902166784 (3721.40 GiB 3995.82 GB) Raid Devices : 6 Total Devices : 6 Persistence : Superblock is persistent Update Time : Fri Jul 27 07:39:17 2018 State : clean Active Devices : 6 Working Devices : 6 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Name : 33ea2557:data-0 (local to host 33ea2557) UUID : 92b2bc5f:cf375e4b:5dcb468f:89d2bd81 Events : 13331486 Number Major Minor RaidDevice State 9 8 51 0 active sync /dev/sdd3 8 8 35 1 active sync /dev/sdc3 7 8 19 2 active sync /dev/sdb3 6 8 3 3 active sync /dev/sda3 5 8 83 4 active sync /dev/sdf3 4 8 67 5 active sync /dev/sde3 /dev/md/data-1: Version : 1.2 Creation Time : Tue Nov 24 12:23:49 2015 Raid Level : raid5 Array Size : 9766874560 (9314.42 GiB 10001.28 GB) Used Dev Size : 1953374912 (1862.88 GiB 2000.26 GB) Raid Devices : 6 Total Devices : 6 Persistence : Superblock is persistent Update Time : Fri Jul 27 07:39:17 2018 State : clean Active Devices : 6 Working Devices : 6 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Name : 33ea2557:data-1 (local to host 33ea2557) UUID : 4010d079:27f07b46:33b86d75:a3989442 Events : 15523 Number Major Minor RaidDevice State 0 8 68 0 active sync /dev/sde4 1 8 84 1 active sync /dev/sdf4 8 8 4 2 active sync /dev/sda4 9 8 20 3 active sync /dev/sdb4 6 8 36 4 active sync /dev/sdc4 7 8 52 5 active sync /dev/sdd4 /dev/md/data-2: Version : 1.2 Creation Time : Sun Jul 22 21:41:37 2018 Raid Level : raid5 Array Size : 7811566336 (7449.69 GiB 7999.04 GB) Used Dev Size : 3905783168 (3724.85 GiB 3999.52 GB) Raid Devices : 3 Total Devices : 3 Persistence : Superblock is persistent Update Time : Fri Jul 27 07:39:17 2018 State : clean Active Devices : 3 Working Devices : 3 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Name : 33ea2557:data-2 (local to host 33ea2557) UUID : 1530c06e:fec73963:800bf076:2cf6cf0d Events : 5499 Number Major Minor RaidDevice State 0 8 5 0 active sync /dev/sda5 1 8 37 1 active sync /dev/sdc5 2 8 21 2 active sync /dev/sdb5
- mdgm-ntgrNETGEAR Employee Retired
You have a triple layer data volume with md125, md126 and md127 as the three layers.
That means you've vertically expanded your data volume a couple of times.
From the looks of things you may have started out with 4TB disks, then moved to 6TB disks and now onto 10TB disks?
There are only 3 disks showing in md127, sda, sdb and sdc.
If you look at disk_info.log which disk is the 10TB disk you just added. Is it one of those three disks or a different disk? If so, which disk?
What does your partitions.log look like? Do you see the same partitions for the other 10TB disk as for the 3 disks mentioned above?
Hi
Thanks. sdd is the one that is just added (disk_info.log below).
Forgive me - I don't know how to interpret partitions.log:
major minor #blocks name 8 0 9766436864 sda 8 1 4194304 sda1 8 2 524288 sda2 8 3 3902297912 sda3 8 4 1953506020 sda4 8 5 3905914280 sda5 8 16 9766436864 sdb 8 17 4194304 sdb1 8 18 524288 sdb2 8 19 3902297912 sdb3 8 20 1953506020 sdb4 8 21 3905914280 sdb5 8 32 9766436864 sdc 8 33 4194304 sdc1 8 34 524288 sdc2 8 35 3902297912 sdc3 8 36 1953506020 sdc4 8 37 3905914280 sdc5 8 48 9766436864 sdd 8 49 4194304 sdd1 8 50 524288 sdd2 8 51 3902297912 sdd3 8 52 1953506020 sdd4 8 64 5860522584 sde 8 65 4194304 sde1 8 66 524288 sde2 8 67 3902297912 sde3 8 68 1953506020 sde4 8 80 5860522584 sdf 8 81 4194304 sdf1 8 82 524288 sdf2 8 83 3902297912 sdf3 8 84 1953506020 sdf4 9 0 4190208 md0 9 1 1569792 md1 9 127 7811566336 md127 9 126 19510833920 md126 9 125 9766874560 md125
Device: sda Controller: 0 Channel: 0 Model: ST10000VN0004-1ZD101 Serial: ZA27GA65 Firmware: SC60 Class: SATA RPM: 7200 Sectors: 19532873728 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33ea2557 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 End-to-End Errors: 0 Command Timeouts: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 36 Start/Stop Count: 1 Power-On Hours: 179 Power Cycle Count: 1 Load Cycle Count: 165 Device: sdb Controller: 0 Channel: 1 Model: ST10000VN0004-1ZD101 Serial: ZA27GSKS Firmware: SC60 Class: SATA RPM: 7200 Sectors: 19532873728 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33ea2557 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 End-to-End Errors: 0 Command Timeouts: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 37 Start/Stop Count: 1 Power-On Hours: 82 Power Cycle Count: 1 Load Cycle Count: 134 Device: sdc Controller: 0 Channel: 2 Model: ST10000VN0004-1ZD101 Serial: ZA27FV7C Firmware: SC60 Class: SATA RPM: 7200 Sectors: 19532873728 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33ea2557 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 End-to-End Errors: 0 Command Timeouts: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 36 Start/Stop Count: 1 Power-On Hours: 126 Power Cycle Count: 1 Load Cycle Count: 187 Device: sdd Controller: 0 Channel: 3 Model: ST10000VN0004-2GS11L Serial: ZJV03DE8 Firmware: SC60 Class: SATA RPM: 7200 Sectors: 19532873728 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33ea2557 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Command Timeouts: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 38 Start/Stop Count: 9 Power-On Hours: 186 Power Cycle Count: 9 Load Cycle Count: 15 Device: sde Controller: 0 Channel: 4 Model: HGST HDN726060ALE610 Serial: NCG9UA9S Firmware: APGNT517 Class: SATA RPM: 7200 Sectors: 11721045168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33ea2557 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 45 Start/Stop Count: 1659 Power-On Hours: 19379 Power Cycle Count: 852 Load Cycle Count: 2320 Device: sdf Controller: 0 Channel: 5 Model: HGST HDN726060ALE610 Serial: NCG9TPDS Firmware: APGNT517 Class: SATA RPM: 7200 Sectors: 11721045168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33ea2557 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 43 Start/Stop Count: 1607 Power-On Hours: 19378 Power Cycle Count: 852 Load Cycle Count: 2268
I've responded to your PM.
Thanks
Andy
