knKgLhr
Oct 27, 2017Star
After firmware update to 6.9.0 my backup software can't work properly over SMB
Hey, looks like latest firmware update somehow broken my backup pipeline.
I'm using Veeam Endpoint to make automatic everyday backups to the NAS over SMB.
But after firmware update it can't work properly due to this error:
Error: Incorrect function. Agent failed to process method {ReFs.SetFileIntegrity}.
I've submitted a support case to the Veeam Support as well, but this firmware update is an only one change I to my NAS and PC before this error started to appear.
Any thoughts on this issue?
I reproduced the issue using veeam Agent for windows,
See error message "Error: Incorrect function. Agent failed to process method {ReFs.SetFileIntegrity}."
Developter is checking the issue.
Thanks for your report.
- VinzAspirant
Similar issue here. With the latest firmware update 6.9.0 my RN104 no longer backup anything.
When I looked at it this morning it shown every backups on "processing".
I restarted the NAS, they shown as "canceled". Tried to manualy start them, they are still at "processing", when normaly it took a few minutes to complete...
If you are using the windows protocol in a NAS backup job....
Netgear has confirmed one problem here, and is investigating a second.
Hey, StephenB!
Could you please clarify, did Netgear confirmed the ReFs.SetFileIntegrity problem?
Thanks!
- cpu8088Virtuoso
similar situation here with pro 6 firmware 6.9.0
incremental backup job scheduled just stuck with "processing" even the job has been done.
now reverted back to 6.8.1. but i hate the pop up notification that tells me to upgrade to 6.9.0.
how to disable this notification?
BTW I wonder why 6.9.0 is not present at the downloads section?
https://kb.netgear.com/20684/ReadyNAS-Downloads
Is it revoked or something?
Can we downgrade to 6.8.1 without trouble?
- EdouardTutor
Same problem with RN102. Stuck in progress.
- EdouardTutor
Some people said than they successfuly reverted the upgrade. Can you give the procedure to acheive that?
- kohdeeAdministrator
Hello,
We reached out to Veeam and Veeam wants us to have you contact their support for the fix. The fix is in their software.
