sebus46's avatar
sebus46
AjaxExplorer access to home folder
What does one need to configure to have access to user home folder from AjaxExplorer interface?
RN Duo+
Thanks
sebus
  • You mean access to the ReadyNAS user home folder, via Ajaxplorer ? You have to create a repository pointing to the specific folder.
    You mean acces to the Ajaxplorer user home folder ? The default one is located, by default, in /c/webroot/files
  • You have to create a repository pointing to the specific folder
    Correct, but one needs to change the group rights to this folder.
    Good explanation of rights in RN is here
    Just create new group (ie userandadmin ), make it primary for the user, add admin as a secondary member and
    Now all that's left is to set the permissions on the directory:
    sudo chgrp -R userandadmin /path/to/the/directory
    sudo chmod -R 770 /path/to/the/directory
    sebus
ProSupport for Business
