jwishnie
Nov 16, 2014Aspirant
Frontview missing images / JS after USB Recover
ReadyNAS NV+
Just stopped accepting SSH and HTTP connections.
Performed USB Restore with 4.1.14 image from here:
http://www.readynas.com/download/suppor ... 4.1.14.img
Frontview comes up with no images, no iframes, no js. Looks like this:
Performed OS Reinstall.
Same results.
I can ssh to the device now and see the following errors in Frontview error log:
Looking at the Frontview directory, the files do not exists!
What's going on? Can I restore these missing directories from somewhere and get frontview working again?
Same results.
[Sun Nov 16 01:28:16 2014] [error] [client 10.0.0.146] File does not exist: /frontview/ui/resource/js, referer: https://10.0.0.106/admin/
[Sun Nov 16 01:28:16 2014] [error] [client 10.0.0.146] File does not exist: /frontview/ui/resource/images, referer: https://10.0.0.106/admin/
[Sun Nov 16 01:28:16 2014] [error] [client 10.0.0.146] File does not exist: /frontview/ui/resource/theme, referer: https://10.0.0.106/admin/
# ls -a /frontview/ui/resource/
. .. html
- mdgm-ntgrNETGEAR Employee Retired
# df -h
# df -i
USB Boot Recovery really is a last resort and usually other things should be tried first. - jwishnieAspirantUnable to connect to the device on any port and it only responding to ping, USB restore seemed the _least_ drastic thing I could do. But am happy to take your guidance!
# df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/hdc1 128000 26585 101415 21% /
tmpfs 31583 1 31582 1% /USB
/dev/c/c 91455488 690490 90764998 1% /c
# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/hdc1 1.9G 2.0G 9.7M 100% /
tmpfs 16k 0 16k 0% /USB
/dev/c/c 2.7T 2.0T 786G 72% /c - mdgm-ntgrNETGEAR Employee RetiredWell USB Boot Recovery only helps if the firmware on the internal flash is corrupt.
Your output above shows that your 2GB OS partition is full. Since it is full the OS re-install could not complete successfully.
You will need to find what is filling it.
# du -csh /var/*
# du -csh /var/log/*
# du -csh /var/log/frontview/*
# du -csh /var/log/frontview/backup/*
You may wish to copy huge log files onto the data volume /c, then empty them e.g. (note the examples below might not be what is filling the OS partition)///
# mkdir /c/.logs
# cp /var/log/frontview/error.log /c/.logs
# echo "" > /var/log/frontview/error.log
# cp /var/log/upnp-av.log /c/.logs
# echo "" > /var/log/upnp-av.log
After you have freed up some space the next thing would to be check some config files (/etc/default/services, /etc/passwd, /etc/network/interfaces etc.) have not been corrupted and if all is O.K. then do another OS re-install - jwishnieAspirantThank you, that's super helpful. I will look for what is taking the space and let you know if a OS reinstall works once cleaned out.
So far:
/var/cache/minidlna is ~.5GB of cached art...
And Holy Cr*p, kernel.log is ~800MB--is there no logrotation by default? - mdgm-ntgrNETGEAR Employee RetiredWell you could remove that. There's likely other things as well that are filling it up, so keep looking. Usage of the OS partition should be well below 1GB.
Then after the OS Re-install install this Sparc add-on: http://www.readynas.com/forum/viewtopic.php?p=392371#p392371
Installing this add-on once will get the ReadyDLNA cache to be stored on the data volume instead of the OS partition. This would be a help as your OS partition would be less likely to fill up. Installing the Toggle add-on a second time would change it back to using the OS partition (not recommended). - jwishnieAspirantThanks mdgm, looks like Frontview, Kernel, and MiniDLNA logs are the culprits. I use that addon and maybe set up a logrotate cron job...
 - mdgm-ntgrNETGEAR Employee RetiredWe already have log rotation setup though you could make it more aggressive.
Though if those logs filled up extremely quickly they may have been filled after the log rotation was run and before the next scheduled run of log rotation.
