redpola's avatar
redpola
Mac OS X USB recovery drive?
So, I proudly announced to my friend how great my RN104 is. Literally as he watched it said "upgrade firmware?". I clicked yes. Foolish. Now it's hung on "booting".
I look for a fix and discover that I can create a USB recovery drive if I can run PC .exe files. I cannot.
How can I unbrick my new RN104 using my mac? I am a geek and understand how to use dd and manipulate filesystems.
  • Luckily it's pretty simple on the ARM based systems.
    Grab the USB recovery tool from here.
    Grab your firmware from here.
    Use Disk Utility to format the USB drive.
    1 partition, MS-DOS (FAT) format.
    Make sure Master Boot Record is selected under Options.
    Copy to the USB drive:
    1. The "initrd-recovery.gz" and "NTGR_USBBOOT_INFO.txt" files from the "Marvell" directory
    2. The "uImage-recovery" file from the "Marvell/RN104" directory.
    3. The firmware image.
    When you're done the layout should look like so:
    siigna@tatooine /Volumes/USBRECOVERY $ ls -al
    total 134048
    drwxrwxrwx@ 1 siigna  staff      4096 Nov  2 18:21 .
    drwxrwxrwt@ 8 root    admin       272 Nov  2 18:21 ..
    -rwxrwxrwx  1 siigna  staff         0 May 22  2013 NTGR_USBBOOT_INFO.txt
    -rwxrwxrwx  1 siigna  staff  63391744 Oct 27 11:49 ReadyNASOS-6.4.0-arm.img
    -rwxrwxrwx  1 siigna  staff   2048370 Nov 27  2014 initrd-recovery.gz
    -rwxrwxrwx  1 siigna  staff   3161676 Apr 25  2000 uImage-recovery
  • siigna's avatar
    siigna
    NETGEAR Expert
    total 134048
ProSupport for Business
