MInDev
Mar 02, 2014Aspirant
ReadyNAS NV+ won't power on
Hello: about 6 months ago during an overnight thunderstorm I powered off my Netgear ReadyNAS NV+ (using Frontview -> Shutdown) and once it had switched off I disconnected it from its UPS and went back to sleep. When I returned to it in the morning it wouldn't power on. There are no signs of life at all, I've tried plugging it in, unplugging it again, plugging it back in, and holding down the front button for different durations - all to no effect.
There were a couple of previous occasions when I'd turned it off and it didn't immediately come back to life when I pressed the front power button - but mysteriously it did turn on by itself, say, 10 minutes later. Or one time when it refused to switch back on until I'd pressed the power button every day for 2 weeks - then it suddenly sprang back into life again.
I've survived without it for 6 months, but I know I'm living on borrowed time. I keep all of my important files on the NV+ (luckily I had copies of the files I really needed on my PC when this all first happened) and I had it running nightly backups to an external hard disk connected to the USB port on the back.
I can't know for certain, but I think the power supply must have failed. There are no bad smells or anything like that (my first generation 1 NV went out that way quite spectacularly some years ago), it seems to have died a quiet death - but perhaps the problem lies elsewhere?
Anyway, I need to know what my options are (assuming the problem is with the power supply). I can't seem to find a replacement PSU anywhere online. Is there any scope for rigging up a regular PC PSU? I remember some threads on this forum discussing this a while back, but it involved complicated rewiring. Otherwise, does anyone else know where I could source a replacement in the UK?
Alternatively, I'd be very glad to hear any suggestions for coaxing the unit back into operation - maybe there are some tricks I'm not aware of at the moment.
Thank you very much in advance for your help!
- vandermerweMasterHave you read this?
viewtopic.php?t=10259
I'd contact Netgear support even if your unit is not eligible, they may be able to help you find one. - MInDevAspirantHi vandermerwe, thanks for the reply. Yes - in fact, this was exactly what happened to my first Infrant ReadyNAS unit, which was RMA'd and I received my current NV+ to replace it. It's done sterling service until now, but I don't believe this is the cause of failure for this unit. It's lasted a reasonably long time (not regular PC PSU long, but it's given fair service) and it didn't die a fiery death (again, assuming the PSU *is* to blame).
Sorry, I should have mentioned too - I did get in touch with Netgear some time back, this is an except from the reply:
Based on the information you provided it is most likely a PSU failure but not 100% sure though. Usually if a PSU has failed we replace the whole chassis given that it is withing the warranty period. Your ReadyNAS however is not entitle for replacement since it has an expired hardware warranty. Also NETGEAR Inc. do not sell a separate PSU. I would recommend you purchase a PSU online. I found some post on Amazon UK selling NV+ and NV PSU.
Unfortunately I've not been able to find a supplier on Amazon though. - vandermerweMasterWhy don't you just buy a 104?
There is 1 supplier on amazon.co.uk, but there is no buyer feedback. For about 90 pounds more you could get a new disk less 104 from amazon. - MInDevAspirantHi, thank you, something like that might be the solution. But I'm given to understand that - for various reasons - I wouldn't be able to take the disks out of my NV+ and plug them straight into a box like that and have them just 'work' (there are two 1-TB disks set-up in X-RAID configuration)? I seem to remember reading something along those lines when it came to comparing SPARC vs Intel units (I think). Is this accurate? Because it would be very convenient if I could do that.
It seems a shame to junk the existing chassis just because of a fault PSU though. It would be nice if I could bring it back to life somehow. - StephenBGuru - Experienced UserA few old threads that might help:
viewtopic.php?f=33&t=60235#p404263
viewtopic.php?f=11&t=13492
http://www.readynas.com/download/archiv ... pinout.pdf
viewtopic.php?f=11&t=18694
I think there might be some others, but I don't have time to search more...
It might be simpler if you can live with keeping the ATX supply remains external - ugly, and harder to move, but it works around the problem of fitting a stock supply into the chassis.
Note I have not attempted to do this myself. - hokieguyAspirantReviving this old thread as my NV has died this morning. No signs of life whatsoever. I can't check if it falls into the 'bad PSU' range because I don't know the serial #. No sticker on the back and since it's dead I can't check the MAC. :?
The most important thing - my data is safe on an additional backup.
I'm guessing my drives are probably OK. In order to check that, I need to run the disk utilities, correct? No sense trying to revive the NV if the disks are dead, I'll just move to something like the WD MyCloud (yes, I know it's not as capable as a full NAS).
Any suggestions on
1) a different way to check serial #
2) easy, affordable way to replace PSU (if that is the issue)
Edit: Was able to get the MAC from my router. Serial number translates to 58552555787 which appears to fall in the affected range. I've emailed Netgear support, will see what comes of it.
Thanks! - NhellieVirtuosoI don't see any other way on retrieving the MAC/Serial for the unit if it does not have sticker and/or no power. I believe your best bet is to find a compatible power supply for the unit, I'd check the marketplace for parts. I saw one from amazon for $120 (assuming your in the US). http://www.amazon.com/NETGEAR-Spare-Pow ... B000W3X480
or
You can just purhcase the newer OS6 models. :) - hokieguyAspirantThanks - I was able to get the serial # from my router interface. I'm not going to pay $120 for a replacement. If Netgear will not provide a free replacement (since this unit falls in the affected range) or at least sell me one at a reasonable price, I'll probably move on to a cheaper solution like the WD.
- NhellieVirtuosoIf it falls on the range of the affected PSU you should be given free replacement.
- hokieguyAspirantAfter eventually getting escalated to Tier 2 support, they will be shipping me a new PSU free of charge. Tier 1 was not very helpful (asked if the light on the power brick was lit - there is no power brick!!) but happy to have this resolved. Thanks, Netgear. Hopefully this keeps my ReadyNAS chugging for another couple years!
