jmultitache36's avatar
Mar 10, 2015
Interface web admin de mon readyNas 104 inaccessible.
Bonjour à tous,
Depuis quelques jours, suite à une erreur probablement de désinstallation d'une application, je suis sous le firmware 6.2.2.
Je ne peux plus accéder à l'interface de mon "ReadyNas 104", mes partages "SMB" sont toujours actifs, ainsi que mes programmations horaires, mais sauf le "https://192.168.1.72".
Quelqu'un aurait-ils svp, une solution autre qu'un "Reset factory" pour régler ce petit désagrément ?
Merci d'avance.
Bien cordialement.
  • Its a known issue with the firmware version 6.2.2 wherein the web-GUI goes inaccessible after uninstalling Apps. Its best that you contact Netgear Support and they could help you gain access to the web-GUI of your RN102 again: http://support.netgear.com/general/contact/#tab-call -- Be reminded that they might offer you to avail a support contract if ever your support warranty has expired.
    Here is the reason behind the issue: Apache could not start because of sites-enabled which contained “.conf file” left by the App after its been uninstalled. To solve this, a telnet/SSH access to the NAS is needed and that “.conf file” should be removed then restart Apache and the web-GUI of the NAS will be accessible again.
    This issue is already fixed by a new Beta Firmware as per this forum link: viewtopic.php?t=78866
    - Thanks to Google Translate. I am open to corrections. :D
  • Hi, and thanks guy, for your good explaination, finaly I solved my problem.
    it's not easy to solve, but now my Rn104 , working fine.
    Dont worry for the french langue, nothing to corrected, google translator can help us.
    bye
  • I'm glad to know that your RN104 is working fine :D
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
ProSupport for Business
