× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
A6150, installation in MAC OS doesn't work
Tiako
I followed the procedures from Manual, downloaded software for MAC OS installation and then is asks to restart computer.
After i restar, i connect adapter to USB port but the N Icon is not show ins mac's menu bar.
I don't understand why the procedure of the manufacturer doesn't work.
Model: A6150|AC1200 Dual Band WiFi USB Mini Adapter
Message 1 of 4
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: Betreff: A6150, installation in MAC OS doesn't work
Hi @mariogaucher
Its has been a while since Apple started phasing out 32bit apps. MacOS Mojave was the last to support 32bit apps. Engineers advised that A6150 will be compatible with macOS Catalina by Q1 2020.
Blanca
Community Team
Message 4 of 4
All Replies
Tiako
I figured out after some time that the icon appears on the top of the screen, in top bar, and not in the bottom bar. There is also no icon available under apps.
Message 2 of 4
mariogaucher
Hi!
was this intalled on macOS Catalina (10.15)?
I'm looking to buy the same adapter for my old MacBook... and would like to make sure it works in Catalina.
Message 3 of 4
Blanca_O
NETGEAR Moderator
Hi @mariogaucher
Blanca
Community Team
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4018 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
