× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
A6210 does not connect at ac
Alchemist2017
Follower
Hi, I'm using Win10 x64, with A6210 driver 5.1.22.0 running from a USB3 port on ASUS Z170 Pro Gaming board (latest bios)
I have a Unifi AC access point (latest firmware) and other devices on my network connect at ac speeds.
The A6210 does not report ac speeds, only n on the 5Ghz, 149 channel
I have read that this is actually reporting incorrectly, so is there a new driver for this card that will report correctly the current speed?
Task manager says 'n' and I'm getting ~90Mbps when copying files over the link
any help is most greatfully received
cheers
Pete
Model: A6210|AC1200 High Gain Antenna WiFi USB Adapter
Message 1 of 3
JamesGL
Master
Re: A6210 does not connect at ac
Hi Alchemist2017,
I have replied to your PM.
Message 2 of 3
Are you talking about Mbps or Mo/s if it is Mo/s 90x8 = 720 Mbps, that is pretty good!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3229 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
