× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
A7000 No Internet, secured
ThePeskyDingo
Just moved into a new home and got Comcast's xFi gateway for my internet.
No issues connecting to the network on any of myt other devices and even am able to connect old usb WiFi adapters and get my desktop online with them which leads to the issue being with the AC7000.
I can't find any solution on the internet for this that works.  Anyone have a fix?
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 6
Accepted Solutions
Re: A7000 No Internet, secured
@ThePeskyDingo wrote:
It's when I click on the wireless icon in the lower right corner.
Is that the Windows network icon?
If so, that definitely suggests a Windows networking issue.
My first guess is that you may need to tell Windows that you are on a "private network".
  • Network and Internet settings
  • Network Status
  • Change Connection Properties
  • Network Profile
  • Private
Message 4 of 6
All Replies
Likely to be a Windows networking issue.
Where do you see this message?
Message 2 of 6
ThePeskyDingo
Message 3 of 6
  • Network Status
  • Network Profile
  • Private
Message 4 of 6
ThePeskyDingo
This worked!
Thank you.
Message 5 of 6
Many thanks for confirming that. Very helpful.
There are some people around here, one in particular, who confidently dismiss that answer as being rubbish.
You are not the first one to find that it works for them.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 13030 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
