- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to change channel in Smart Wizard
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
Im new to this community and this is my first question
I have a netgear WNA3100 wifi adapter and the last weeks my wireless network has been very unstable. Googled it found out that change channel could be a solution
Have downloaded the inSSIDer, but its not possible to change channel in that program
How can I change channel in smart wizard which is the WNA3100 utility?
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Wi-Fi channel used by the WNA3100 is determined by the Wi-Fi router or Access point that it's connected to. You would need to log into the router or Access point and change the channel, there.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to change channel in Smart Wizard
Didnt knew how to log in to a router, but googled it and logged in. Now I have access to the router, and I hope that choosing channel 11 instead of auto will help, to get the wifi more stable
Just adding the the IP-adress in the andress bar on the browser, then the log in page for the router will appear
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have four WN2500RPs. Got a way to put them all on a unique channel from the same router... would be a lot more versatile if it could be changed the other way around.
