- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear wireless adapter AC600
- Mark as New
- Bookmark
- Subscribe
- Permalink
can this wireless ac adapter be used in the dish receiver to get wi-fl for movies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear wireless adapter AC600
Need way more to go off and not sure if netgear is the appropriate place to ask this. You'd need to look up your dish receiver and compatible adapters on their website. you're posting didn't list which receiver or if you'd tried. If you can't find the info you can always go with a ethernet wifi adapter OR powerline adapter to give you a connection without worrying about compatibility.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The A6100 is a USB device that allows Windows PCs to connect to the wifi.
Check the "System Requirements" in the Data Sheet.
>>>> A6100 | Product | Support <<<<
It will not add wifi capability to anything else.
