× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
No NETGEAR A7000 Plug in
medheed
Follower
I have just bought the A7000 Nighthawk WiFi USB adapter. I had no problems with driver installation, and the A7000 is listed as registering with my USB port according to the system report.. however I still have the 'No NETGEAR A7000 Plug in' message showing in my extensions, and the WPS (LED) light won't turn on.
Other USB devices work in the ports - and I can only think that the unit itself is faulty. Can someone suggest any further tests I should do before returning the device?
Thanks.
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 2
Re: No NETGEAR A7000 Plug in
@medheed wrote:
I still have the 'No NETGEAR A7000 Plug in' message showing in my extensions.
What does that mean? What are these "extensions"?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 827 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
