sargunner
Feb 13, 2016Aspirant
WNA3100M Connection Problem
After trying 7 - 8 times I have installed the driver to WNA3100M N300 USB Mini Adapter and it recognise the router but there is no connection. In a prvious installation I had light in the adapter but it has gone now and that might be the problem. I have tried different USB connections. I am runnning Windows 10 Pro and I have installed the verson 1.2.0.6 which should be the latesy version. I have also removed the Mediatek drivers. I cannot find any more to do. Wkat do I di now?
- JamesGLNETGEAR Employee Retired
Hi sargunner,
Try to install the standalone driver. If still the same, try to install it on a different computer just to isolate if the adapter is faulty or not working.
- sargunnerAspirant
Thank you for your kind suggestions but I have tried thar without success. Thank you:-)))))
- sargunnerAspirant
Do I use the right driver? I have installed the latest one starting with 1?
- sargunnerAspirant
I have now bougt another Netgear adapter - N600 -and I have still no internetconnection. This one tells me yhat i have connection to the router - also Netgear - but no internet. I have moved my computer to 1 meter from the router and I have changed channel three times. No connection. Maybe I wil lreinstall Windows 10 but I cannot see how that should help. I had a connection until a week ago but I have not found out whybI lost it. I have contacted the internet provider but I have not had any answers yet. Strange😨
- nginxAspirant
I'm having the same problrm. Can anyonce provide me link for driver for WN3100M v1 wifi card for ubuntu os please.
