MikeStahl's avatar
MikeStahl
5GHz doesn't light but shows on devices
My router from what I read doesn't have 5GHz only 2.4. 5 GHz light not on extender but the 5GHz wifi name along with 2.4 show up on my IPAD. (not IPHONE). What's going on? The 5 is stronger signal. How am I getting 5GHz band when my router is not dual band and Extender 5GHz band not lit
  • MODEL of the unit
    I'm sure you are not the only has wifi around you. You may simply getting someone else SSID network
  • OK, it can broadcast on both bands even if it receives only one of the two bands (2.4 and 5 GHz).
    But is it possible to force the repeater not to broacast anything on one of the two bands? I mean that if I have already many devices on the 2.4 GHz band, can I prevent the WN2500RP to add noise on this band and communicate only on the 5 GHz band?
  • I'm answering myself: apparently according to the user's guide, it is possible to activate/deactivate the access point function on each band separately.
    • usually you can disable by the user if you go in the web interface of the unit
    • I have same problem. The WN2500RP just wont connect to router at 5ghz. Devices can see and connect 5GHZ band on WN2500RP but because WN2500RP cannot connect to router at 5ghz, the devices have not LAN/Internet access.
      The led for 5ghz on the WN2500RP does not illuminate- although on cycling off/on it does display on diagnostic start up.
      Now on second (replacement unit).
      As is other post I think its a dud.
    • I have the same problem. The modem broadcasts dual band and the extender broadcasts both bands. However, the 5Ghz led never comes on. My first contact with Netgear said I had a bad range extender. Returned it and got another one. Had the same problem!!! When I called for support again, was told it was a hardware "GLITCH" that would be fixed. That was late October. Just today I tried to get a status on a fix and have been going round and round getting no where. Tech's want me to redo setup that I've already done multiple times. Can't seem to get to the person that said it was a "glitch" and really knows what's going on!!!
    • My WN 2500RP worked exactly as advertised for two weeks after a flawless two minute set up. Then the 5Ghz connection disappeard and the 2.4 dropped in signal quality. Extender has not been moved
